ArcGIS.Desktop.Mapping Namespace / StandaloneTableFactory Class / CreateStandaloneTable Method / CreateStandaloneTable(StandaloneTableCreationParams,IStandaloneTableContainerEdit) Method
A StandaloneTableCreationParams object.
A map or group layer where the StandaloneTable will be added
Example
    Creates a new StandaloneTable instance using the specified StandaloneTableCreationParams and adds it to a container such as a map. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Parameters
    tableParams
    container
    Return Value
    Exceptions
    ExceptionDescription
    StandaloneTableCreationParams or container is null.
    Example
    Create a StandaloneTable
        //container can be a map or group layer
        var container = MapView.Active.Map;
        //var container =  MapView.Active.Map.GetLayersAsFlattenedList()
        //                                  .OfType<GroupLayer>().First();
        //Note: Run within a QueuedTask
        //use a local path
        var table = StandaloneTableFactory.Instance.CreateStandaloneTable(
            new Uri(@"C:\Temp\Data\SDK.gdb\EarthquakeDamage", UriKind.Absolute), container);
        //use a URI to a feature service table endpoint
        var table2 = StandaloneTableFactory.Instance.CreateStandaloneTable(
                      new Uri(@"https://bexdog.esri.com/server/rest/services/FeatureServer" + "/2", UriKind.Absolute), container);
        //Use an item
        var item = ItemFactory.Instance.Create(@"C:\Temp\Data\SDK.gdb\ParcelOwners");
        var tableCreationParams = new StandaloneTableCreationParams(item);
        var table3 = StandaloneTableFactory.Instance.CreateStandaloneTable(tableCreationParams, container);
        //use table creation params
        var table_params = new StandaloneTableCreationParams(item)
            DefinitionQuery = new DefinitionQuery(whereClause: "LAND_USE = 3", name: "Landuse")
        var table4 = StandaloneTableFactory.Instance.CreateStandaloneTable(table_params, container);
    Requirements
