ArcGIS.Desktop.Core Namespace / GeoprocessingOptions Class / SetAddOutputDatasetsToOpenMap Method
Boolean indicating if output datasets are to be added to an open map.
    Sets whether output datasets created by geoprocessing tools should be automatically added to an open map. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    public void SetAddOutputDatasetsToOpenMap(
       bool addOutputDatasetsToOpenMap
    Public Sub SetAddOutputDatasetsToOpenMap( _
       ByVal addOutputDatasetsToOpenMap As Boolean _
    Parameters
    Exceptions
    ExceptionDescription
    Remarks
    Note: see ArcGIS.Desktop.Core.Geoprocessing.GPExecuteToolFlags for available options for modifying behavior of ArcGIS.Desktop.Core.Geoprocessing.Geoprocessing.ExecuteToolAsync. Changing these parameters modifies behavior of interactive GP tools
    Requirements
