ArcGIS.Desktop.Core Namespace / GeoprocessingOptions Class / SetOverwriteExistingDatasets Method
Boolean indicating if datasets can be overwritten.
    Sets whether geoprocessing tools can overwrite existing data, layers, or files when run. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    public void SetOverwriteExistingDatasets(
       bool overwriteExistingDatasets
    Public Sub SetOverwriteExistingDatasets( _
       ByVal overwriteExistingDatasets As Boolean _
    Parameters
    Exceptions
    ExceptionDescription
    Remarks
    Note: see ArcGIS.Desktop.Core.Geoprocessing.GPExecuteToolFlags for available options for modifying behavior of ArcGIS.Desktop.Core.Geoprocessing.Geoprocessing.ExecuteToolAsync. Changing these parameters modifies behavior of interactive GP tools
    Requirements
