ArcGIS.Core.CIM Namespace / CIMClassBreaksRendererBase Class
Properties Methods Events
    CIMClassBreaksRendererBase Class Members
    The following tables list the members exposed by CIMClassBreaksRendererBase.
    Public Properties
     NameDescription
    Public Property Gets or sets a value indicating whether or not to automatically update class labels whenever a class upper value is changed.
    Public Property Gets or sets the additional authoring information used by the renderer.
    Public Property Gets or sets the background symbol used for graduated symbols.
    Public Property Gets or sets the barrier weight used for graduated symbols to avoid labels.
    Public Property Gets or sets the class breaks.
    Public Property Gets or sets the class break type.
    Public Property Gets or sets the classification method.
    Public Property Gets or sets the color ramp.
    Public Property Gets or sets the default description.
    Public Property Gets or sets the default label.
    Public Property Gets or sets the default symbol.
    Public Property Gets or sets the custom patch for the default symbol.
    Public Property Gets or sets the patch shape for the default symbol.
    Public Property Gets or sets a value indicating whether or not to draw graduated symbols for polygon features above all layers.
    Public Property Gets or sets the field for rendering.
    Public Property Gets or sets the heading.
    Public Property Gets or sets the minimum break.
    Public Property Gets or sets the minimum label.
    Public Property Gets or sets the number format.
    Public Property Gets or sets the property that controls how the color ramp is applied to polygon symbols.
    Public Property Gets or sets the maximum number of records to sample.
    Public Property Gets or sets a value indicating whether or not to show class gaps.
    Public Property Gets or sets a value indicating whether or not to show classes in ascending order.
    Public Property Gets or sets a value indicating whether or not to use the default symbol.
    Public Property Gets or sets ExpressionInfo that contains the Arcade expression that returns value as a number. When both Fields and ValueExpressionInfo are present ValueExpressionInfo is used.
    Top
    Public Methods
     NameDescription
    Public Method Not implemented, reserved for future use. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Public Method Reads the element inside the reader. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Public Method Creates a JSON encoding of the CIMObject and its current state. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Public Method Writes the element inside the writer. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Top
    Protected Methods
     NameDescription
    Protected Method Called from a property setter to notify the framework that an Object member has changed. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Protected MethodOverridden.  Reads the child element inside the reader.
    Protected MethodOverridden.  Writes a child element to the writer.
    Top
    Public Events
     NameDescription
    Public Event Occurs when a property value changes. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Top
