public VersionBaseType GetCurrentVersionBaseType()
Public Function GetCurrentVersionBaseType() As VersionBaseType
Return Value
The type of VersionBase of the current Version.
VersionManager belongs to a Geodatabase that is connected to a Version or a HistoricalVersion.public VersionBaseType GetCurrentVersionBaseType()
| Exception | Description |
| ArcGIS.Core.Data.Exceptions.GeodatabaseVersionException | The current VersionBase is invalid. |
| ArcGIS.Core.Data.Exceptions.GeodatabaseException | A geodatabase-related exception has occurred. |
Task ChangeVersionsAsync(Geodatabase geodatabase, string toVersionName)
var map = MapView.Active?.Map;
if (map == null)
return Task.CompletedTask;
return QueuedTask.Run(() =>
using (VersionManager versionManager = geodatabase.GetVersionManager())
VersionBaseType versionBaseType = versionManager.GetCurrentVersionBaseType();
if (versionBaseType == VersionBaseType.Version)
Version fromVersion = versionManager.GetCurrentVersion();
Version toVersion = versionManager.GetVersion(toVersionName);
// Switch between versions
map.ChangeVersion(fromVersion, toVersion);
if (versionBaseType == VersionBaseType.HistoricalVersion)
HistoricalVersion fromHistoricalVersion = versionManager.GetCurrentHistoricalVersion();
HistoricalVersion toHistoricalVersion = versionManager.GetHistoricalVersion(toVersionName);
// Switch between historical versions
map.ChangeVersion(fromHistoricalVersion, toHistoricalVersion);
// Switch from HistoricalVersion to Version and vice-versa
// map.ChangeVersion(fromHistoricalVersion, toVersion);
// map.ChangeVersion(fromVersion, toHistoricalVersion);
