ArcGIS.Core.Geometry Namespace / PolygonBuilderEx Class / PolygonBuilderEx Constructor / PolygonBuilderEx Constructor(IEnumerable<MapPoint>,AttributeFlags,SpatialReference)
Points for the first ring. Line segments are created from the points.
AttributeFlags to set the HasZ, HasM and HasID attributes. If no attributes should be set, pass AttributeFlags.None. If all attributes should be set, pass AttributeFlags.AllAttributes. Use the bitwise OR operator to set two attributes. For example, to set HasZ = true and HasM = true, pass AttributeFlags.HasZ | AttributeFlags.HasM.
(Optional) The SpatialReference. The default value is null. The spatial reference of each point is ignored.
Example
    Initializes a new instance of the PolygonBuilderEx class.
    Syntax
    Parameters
    points
    attributes
    spatialReference
    Exceptions
    ExceptionDescription
    The input mapPoint enumeration is null.
    Example
    Builder Properties
      // list of points
      List<MapPoint> pointsForBuilder = new List<MapPoint>
      MapPointBuilderEx.CreateMapPoint(0, 0, 2, 3, 1),
      MapPointBuilderEx.CreateMapPoint(1, 1, 5, 6),
      MapPointBuilderEx.CreateMapPoint(2, 1, 6),
      MapPointBuilderEx.CreateMapPoint(0, 0)
      // will have attributes because it is created with convenience method
      Polyline polylineWithAttrs = PolylineBuilderEx.CreatePolyline(pointsForBuilder);
      bool hasZ = polylineWithAttrs.HasZ;          // hasZ = true
      bool hasM = polylineWithAttrs.HasM;          // hasM = true
      bool hasID = polylineWithAttrs.HasID;        // hasID = true
      // will not have attributes because it is specified as a parameter
      Polyline polylineWithoutAttrs =
        PolylineBuilderEx.CreatePolyline(pointsForBuilder, AttributeFlags.None);
      hasZ = polylineWithoutAttrs.HasZ;          // hasZ = false
      hasM = polylineWithoutAttrs.HasM;          // hasM = false
      hasID = polylineWithoutAttrs.HasID;        // hasID = false
      Polygon polygonWithAttrs = PolygonBuilderEx.CreatePolygon(pointsForBuilder);
      hasZ = polygonWithAttrs.HasZ;               // hasZ = true
      hasM = polygonWithAttrs.HasM;               // hasM = true
      hasID = polygonWithAttrs.HasID;             // hasID = true
      Polygon polygonWithoutAttrs =
            PolygonBuilderEx.CreatePolygon(pointsForBuilder, AttributeFlags.None);
      hasZ = polygonWithoutAttrs.HasZ;               // hasZ = false
      hasM = polygonWithoutAttrs.HasM;               // hasM = false
      hasID = polygonWithoutAttrs.HasID;             // hasID = false
      PolylineBuilderEx polylineB =
                 new PolylineBuilderEx(pointsForBuilder, AttributeFlags.None);
      hasZ = polylineB.HasZ;                      // hasZ = false
      hasM = polylineB.HasM;                      // hasM = false
      hasID = polylineB.HasID;                    // hasID = false
      // will have attributes because it is passed an attributed polyline
      polylineB = new PolylineBuilderEx(polylineWithAttrs);
      hasZ = polylineB.HasZ;                      // hasZ = true
      hasM = polylineB.HasM;                      // hasM = true
      hasID = polylineB.HasID;                    // hasID = true
      // will not have attributes because it is passed a non-attributed polyline
      polylineB = new PolylineBuilderEx(polylineWithoutAttrs);
      PolygonBuilderEx polygonB = new PolygonBuilderEx(pointsForBuilder, AttributeFlags.None);
      hasZ = polygonB.HasZ;                       // hasZ = false
      hasM = polygonB.HasM;                       // hasM = false
      hasID = polygonB.HasID;                     // hasID = false
      // will have attributes because it is passed an attributed polygon
      polygonB = new PolygonBuilderEx(polygonWithAttrs);
      hasZ = polygonB.HasZ;                       // hasZ = true
      hasM = polygonB.HasM;                       // hasM = true
      hasID = polygonB.HasID;                     // hasID = true
      // will not have attributes because it is passed a non-attributed polygon
      polygonB = new PolygonBuilderEx(polygonWithoutAttrs);
    Construct a Polygon - from an enumeration of MapPoints
      // Use a builderEx convenience method or use a builderEx constructor.
      MapPoint pt1 = MapPointBuilderEx.CreateMapPoint(1.0, 1.0);
      MapPoint pt2 = MapPointBuilderEx.CreateMapPoint(1.0, 2.0);
      MapPoint pt3 = MapPointBuilderEx.CreateMapPoint(2.0, 2.0);
      MapPoint pt4 = MapPointBuilderEx.CreateMapPoint(2.0, 1.0);
      List<MapPoint> list = new List<MapPoint>() { pt1, pt2, pt3, pt4 };
      Polygon polygonFromPoints = PolygonBuilderEx.CreatePolygon(list, SpatialReferences.WGS84);
      // polygon.HasZ will be false - it is determined by the HasZ flag of the points in the list
      // or specifically use AttributeFlags.NoAttributes
      polygonFromPoints = PolygonBuilderEx.CreatePolygon(list, AttributeFlags.None);
      // use AttributeFlags.None as we have 2D points
      PolygonBuilderEx polygonBuilder = new PolygonBuilderEx(list, AttributeFlags.None);
      polygonBuilder.SpatialReference = SpatialReferences.WGS84;
      polygonFromPoints = polygonBuilder.ToGeometry();
    Requirements
