ArcGIS.Core.Data Namespace / Row Class
    Row Class Methods
    For a list of all members of this type, see Row members.
    Public Methods
     NameDescription
    Public Method Adds a given attachment to a row. This method must be called on the MCT. Use QueuedTask.Run.
    Public Method Deletes the row. This method must be called on the MCT. Use QueuedTask.Run.
    Public Method Deletes attachment(s) provided by attachmentID that are associated with the row. This method must be called on the MCT. Use QueuedTask.Run.
    Public Method (Inherited from ArcGIS.Core.CoreObjectsBase)
    Public Method Gets the index position for a field by name. This method must be called on the MCT. Use QueuedTask.Run.
    Public MethodGets a IReadOnlyList of attachments based on the requested attachmentIDs for a given row. This method must be called on the MCT. Use QueuedTask.Run.
    Public MethodGets a IReadOnlyList containing the fields of the row. This method must be called on the MCT. Use QueuedTask.Run.
    Public MethodGets the global ID in the form of System.Guid associated with the row. If the row does not have a global ID, an empty Guid is returned. This method must be called on the MCT. Use QueuedTask.Run.
    Public Method Gets the object ID of the row. This method must be called on the MCT. Use QueuedTask.Run.
    Public Method Gets the original value of a field at the given index. This method must be called on the MCT. Use QueuedTask.Run.
    Public MethodGets the parent Table of this row. This method must be called on the MCT. Use QueuedTask.Run.
    Public Method Gets a value indicating whether the value of the field at the given index has changed. This method must be called on the MCT. Use QueuedTask.Run.
    Public Method Stores the row. This method must be called on the MCT. Use QueuedTask.Run.
    Public Method Updates the properties of an existing attachment fetched using GetAttachment with new values This method must be called on the MCT. Use QueuedTask.Run.
    Top
