ArcGIS.Desktop.Layouts Namespace / ElementFactory Class / CreatePredefinedShapeGraphicElement Method / CreatePredefinedShapeGraphicElement(IElementContainer,PredefinedShape,MapPoint,Double,Double,CIMPolygonSymbol,String,Boolean,ElementInfo) Method
The parent element container
The shape type of the graphic
The location of the graphic
The width of the graphic bounding box (optional)
The height of the graphic bounding box (optional)
The symbol to be used with the graphic (optional)
An element name (optional)
Select after create flag (default is true) (optional)
Additional element properties (optional)
Example
    Create a polygon graphic of the specified PredefinedShape using the provided location, optional size dimensions, and symbol. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Public Overloads Function CreatePredefinedShapeGraphicElement( _
       ByVal elementContainer As IElementContainer, _
       ByVal shapeType As PredefinedShape, _
       ByVal location As MapPoint, _
       Optional ByVal width As Double, _
       Optional ByVal height As Double, _
       Optional ByVal polySymbol As CIMPolygonSymbol, _
       Optional ByVal elementName As String, _
       Optional ByVal select As Boolean, _
       Optional ByVal elementInfo As ElementInfo _
    ) As GraphicElement
    Parameters
    elementContainer
    shapeType
    location
    width
    height
    polySymbol
    elementName
    select
    elementInfo
    Return Value
    Exceptions
    ExceptionDescription
    empty or null geometry
    Remarks
    If neither a width or height is provided, the dimensions of the graphic bounding box will use a predefined system default. If only one of width or height is provided then the dimensions will be assumed to be equal. Negative width and height values will be treated the same as if they were missing. When generating a circle (i.e. PredefinedShape.Circle) width is used as the circle diameter. When generating an ellipse (i.e. PredefinedShape.Ellipse) width and height are assumed to be the length of the two axis - major/minor depending on which dimension is the longest.
    Example
    Create rectangle graphic with simple symbology
      //Create a simple 2D rectangle graphic and apply simple fill and
      //outline symbols.
      //Note: Must be on QueuedTask.Run
      //Build 2D envelope geometry
      Coordinate2D rec_ll = new Coordinate2D(1.0, 4.75);
      Coordinate2D rec_ur = new Coordinate2D(3.0, 5.75);
      Envelope rec_env = EnvelopeBuilderEx.CreateEnvelope(rec_ll, rec_ur);
      //Set symbology, create and add element to layout
      CIMStroke outline = SymbolFactory.Instance.ConstructStroke(
        ColorFactory.Instance.BlackRGB, 5.0, SimpleLineStyle.Solid);
      CIMPolygonSymbol polySym = SymbolFactory.Instance.ConstructPolygonSymbol(
        ColorFactory.Instance.GreenRGB, SimpleFillStyle.DiagonalCross, outline);
      GraphicElement recElm = ElementFactory.Instance.CreateGraphicElement(
        layout, rec_env, polySym, "New Rectangle");
      //Or use Predefined shape
      GraphicElement recElm2 = ElementFactory.Instance.CreatePredefinedShapeGraphicElement(
                                layout, PredefinedShape.Rectangle, rec_env, polySym,
                                "New Rectangle2");
    Create Predefined Shape Graphic Element
      PredefinedShape shapeType = PredefinedShape.Circle;
      //PredefinedShape shapeType =
      //              PredefinedShape.Circle | Cloud | Cross |Circle | Triangle | ... ;
      //Build geometry
      Coordinate2D ll = new Coordinate2D(4, 2.5);
      Coordinate2D ur = new Coordinate2D(6, 4.5);
      Envelope env = EnvelopeBuilderEx.CreateEnvelope(ll, ur);
      var outline = SymbolFactory.Instance.ConstructStroke(
                      ColorFactory.Instance.BlueRGB, 2);
      var poly_sym = SymbolFactory.Instance.ConstructPolygonSymbol(
                       null, outline);
      var ge = ElementFactory.Instance.CreatePredefinedShapeGraphicElement(
                             layout, shapeType, env.Center, env.Width, env.Height,
                              poly_sym, shapeType.ToString(), true);
    Create Predefined Shape Graphic Element 2
      //Build geometry
      Coordinate2D ll = new Coordinate2D(6.5, 7);
      Coordinate2D ur = new Coordinate2D(9, 9);
                      ColorFactory.Instance.GreenRGB, 2);
                       null, outline);
        layout, PredefinedShape.RoundedRectangle, env, poly_sym, "Rounded Rect", true);
    Create Predefined Shape Graphic Element 3
      //Build geometry
      Coordinate2D center = new Coordinate2D(2, 2.75);
      var eabElp = new EllipticArcBuilderEx(
                               center, 0, 1, 0.45, ArcOrientation.ArcClockwise);
      var ellipse = eabElp.ToSegment();
                            ColorFactory.Instance.GreenRGB, 2.0, SimpleLineStyle.Dot);
      CIMPolygonSymbol ellipseSym = SymbolFactory.Instance.ConstructPolygonSymbol(
                       ColorFactory.Instance.GreyRGB, SimpleFillStyle.Vertical, outline);
      var poly = PolygonBuilderEx.CreatePolygon(
        PolylineBuilderEx.CreatePolyline(ellipse, AttributeFlags.AllAttributes));
        layout, PredefinedShape.Ellipse, poly.Extent.Center, 0, 0, ellipseSym,
        "New Ellipse2", false, new ElementInfo() { Anchor = Anchor.TopRightCorner });
    Requirements
