ArcGIS.Desktop.Layouts Namespace / IElementFactory Interface / CreateGraphicElement Method / CreateGraphicElement(IElementContainer,CIMGraphic,String,Boolean,ElementInfo) Method
The parent element container
The input graphic
Element name (optional)
Select after create flag (default is true) (optional)
Additional element properties (optional)
Example
    Create a GraphicElement based on the input ArcGIS.Core.CIM.CIMGraphic and element properties.
    Syntax
    Overloads Function CreateGraphicElement( _
       ByVal elementContainer As IElementContainer, _
       ByVal cimGraphic As CIMGraphic, _
       Optional ByVal elementName As String, _
       Optional ByVal select As Boolean, _
       Optional ByVal elementInfo As ElementInfo _
    ) As GraphicElement
    Parameters
    elementContainer
    cimGraphic
    The input graphic
    elementName
    select
    elementInfo
    Return Value
    Remarks
    Example
    Create Graphic Element using CIMGraphic
      //Note: on the QueuedTask
      //Place symbol on the layout
      MapPoint location = MapPointBuilderEx.CreateMapPoint(new Coordinate2D(9, 1));
      //specify a symbol
      var pt_symbol = SymbolFactory.Instance.ConstructPointSymbol(
                            ColorFactory.Instance.GreenRGB);
      //create a CIMGraphic
      var graphic = new CIMPointGraphic()
        Symbol = pt_symbol.MakeSymbolReference(),
        Location = location //center of map
      //Or use GraphicFactory
      var graphicFactory = GraphicFactory.Instance.CreateSimpleGraphic(location, pt_symbol);
      ElementFactory.Instance.CreateGraphicElement(layout, graphic);
      ElementFactory.Instance.CreateGraphicElement(layout, graphicFactory);
    Create Graphic Element using CIMSymbol
      //Note: Must be on QueuedTask.Run
      //specify a symbol
      ElementFactory.Instance.CreateGraphicElement(layout, location, pt_symbol);
    Create Picture Graphic Element using CIMSymbol
      //Note: Must be on QueuedTask.Run(() => { ...
      //Build geometry
      Coordinate2D ll = new Coordinate2D(0.5, 1);
      Coordinate2D ur = new Coordinate2D(2.5, 2);
      Envelope env = EnvelopeBuilderEx.CreateEnvelope(ll, ur);
      //Create and add element to layout
      string picPath = System.IO.Path.Combine(Environment.GetFolderPath(Environment.SpecialFolder.MyPictures),
        "SamplePicture.jpg");
      var pic_gr = ElementFactory.Instance.CreatePictureGraphicElement(
        layout, env.Center, picPath, "New Picture", true, new ElementInfo() { Anchor = Anchor.CenterPoint });
    Requirements
