ArcGIS.Desktop.Layouts Namespace / IElementFactory Interface / CreateMapFrameElement Method
The parent element container
The map frame location, envelope, or polygon
The map (to be) associated with the frame (can be null)
An element name (optional)
Select after create flag (default is true) (optional)
Additional element properties (optional)
    CreateMapFrameElement Method (IElementFactory)
    Create a map frame element based on the input map frame polygon and map URI.
    Syntax
    Function CreateMapFrameElement( _
       ByVal elementContainer As IElementContainer, _
       ByVal frameOrLocation As Geometry, _
       ByVal map As Map, _
       Optional ByVal elementName As String, _
       Optional ByVal select As Boolean, _
       Optional ByVal elementInfo As ElementInfo _
    ) As MapFrame
    Parameters
    elementContainer
    frameOrLocation
    map
    elementName
    select
    elementInfo
    Return Value
    Remarks
    Graphic layers are not valid containers for map frames.
    If a point is provided as the frame geometry then a default extent will be applied.
    Requirements
