ArcGIS.Desktop.Layouts Namespace / IElementFactory Interface / CreateTextGraphicElement Method
The parent element container
The type of text graphic to create
The geometry for the resulting graphic
The text symbol to be used with the graphic (optional)
The text string (optional)
An element name (optional)
Select after create flag (default is true) (optional)
Additional element properties (optional)
    CreateTextGraphicElement Method (IElementFactory)
    Creates a text graphic based on the input geometry, symbol, and text and other optional parameters.
    Syntax
    Function CreateTextGraphicElement( _
       ByVal elementContainer As IElementContainer, _
       ByVal textType As TextType, _
       ByVal geometry As Geometry, _
       Optional ByVal textSymbol As CIMTextSymbol, _
       Optional ByVal text As String, _
       Optional ByVal elementName As String, _
       Optional ByVal select As Boolean, _
       Optional ByVal elementInfo As ElementInfo _
    ) As GraphicElement
    Parameters
    elementContainer
    textType
    geometry
    textSymbol
    text
    elementName
    select
    elementInfo
    Return Value
    Remarks
    For:
    • TextType.PointText use a point
    • TextType.SplinedText use a polyline (straight or curved)
    • TextType.CircleParagraph use a circle (polygon) or point
    • TextType.EllipseParagraph use an ellipse (polygon) or point
    • TextType.RectangleParagraph use an envelope or point
    • TextType.PolygonParagraph use a polygon or point
    If a point is used as the input for the paragraph text types, a default element extent is applied.
    Use CreateGraphicElement(IElementContainer,CIMGraphic,String,Boolean,ElementInfo) if you want to use a text graphic previously created, eg via: GraphicFactory.CreateSimpleTextGraphic
    Requirements
