ArcGIS.Desktop.Mapping Namespace / ElevationLayerCreationParams Class / CanCreateElevationSourceLayerFor Method / CanCreateElevationSourceLayerFor(Item,ElevationSurfaceLayer) Method
    Check if an elevation source layer can be created and added to a given surface based on a given item.
    Syntax
    public static bool CanCreateElevationSourceLayerFor(
       Item sourceLayerItem,
       ElevationSurfaceLayer surfaceLayer
    Public Overloads Shared Function CanCreateElevationSourceLayerFor( _
       ByVal sourceLayerItem As Item, _
       ByVal surfaceLayer As ElevationSurfaceLayer _
    ) As Boolean
    Parameters
    sourceLayerItem
    surfaceLayer
    Exceptions
    ExceptionDescription
    Requirements
