ArcGIS.Desktop.Mapping Namespace / FeatureSceneLayer Class / FeatureSceneLayerType Property
Example
    Gets the scene layer type.
    Syntax
    Public ReadOnly Property FeatureSceneLayerType As FeatureSceneLayerType
    public FeatureSceneLayerType FeatureSceneLayerType {get;}
    Property Value
    Example
    Search Rows on the FeatureSceneLayer
      if (!featSceneLayer.HasAssociatedFeatureService)
        return;//Search and Select not supported
      //Multipatch (Object3D) or point?
      //var is3dObject = ((ISceneLayerInfo)featSceneLayer).SceneServiceLayerType
      //                                  == esriSceneServiceLayerType.Object3D;
      var is3dObject = featSceneLayer.FeatureSceneLayerType == FeatureSceneLayerType.Object3D;
      // Note: call within QueuedTask.Run()
        var queryFilter = new QueryFilter
          WhereClause = "Name = 'Ponderosa Pine'",
          SubFields = "*"
        int rowCount = 0;
        //or select... var select = featSceneLayer.Select(queryFilter)
        using (RowCursor rowCursor = featSceneLayer.Search(queryFilter))
          while (rowCursor.MoveNext())
            using (var feature = rowCursor.Current as Feature)
              oid = feature.GetObjectID();
              var shape = feature.GetShape();
              var attrib = feature["Name"];
              if (is3dObject)
                //shape is a multipatch
              else
                //shape is a point
              rowCount += 1;
    Requirements
