ArcGIS.Desktop.Mapping Namespace / Map Class / MoveLayer Method / MoveLayer(Layer,GroupLayer,Int32) Method
A layer.
The layer container to move the layer to.
The position specified by the 0-based index. -1 will move the layer the bottom of the container. If the index is invalid, the layer is moved to the bottom of the container.
    Moves a layer to a different position in the specified targetlayer container. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    public void MoveLayer(
       Layer layer,
       GroupLayer targetLayer,
       int position
    Public Overloads Sub MoveLayer( _
       ByVal layer As Layer, _
       ByVal targetLayer As GroupLayer, _
       ByVal position As Integer _
    Parameters
    layer
    A layer.
    targetLayer
    position
    Exceptions
    ExceptionDescription
    The layer is null.
    Remarks
    If targetLayer is null, the layer is moved to the specified position within the map.
    Requirements
