ArcGIS.Desktop.Mapping Namespace / WMSLayer Class
Members Example
    WMSLayer Class
    Represents a OGC WMS layer.
    Object Model
    WMSLayer ClassLayer ClassStandaloneTable ClassCIMDataConnection ClassTimeExtent ClassCIMBaseLayer ClassElevationTypeDefinition ClassSpatialReference ClassTimeParameters ClassSurfaceZsResult ClassMap ClassILayerContainer InterfaceEnvelope Class
    Syntax
    Example
    Adding and changing styles for WMS Service Layer
        var serverConnection = new CIMInternetServerConnection { URL = "https://spritle.esri.com/arcgis/services/sanfrancisco_sld/MapServer/WMSServer" };
        var connection = new CIMWMSServiceConnection { ServerConnection = serverConnection };
        LayerCreationParams parameters = new LayerCreationParams(connection);
        parameters.MapMemberPosition = MapMemberPosition.AddToBottom;
        //Note: Needs QueuedTask to run
        var compositeLyr = LayerFactory.Instance.CreateLayer<WMSLayer>(parameters, MapView.Active.Map);
        //wms layer in ArcGIS Pro always has a composite layer inside it
        var wmsLayers = compositeLyr.Layers[0] as ServiceCompositeSubLayer;
        //each wms sublayer belongs in that composite layer
        var highwayLayerWMSSub = wmsLayers.Layers[1] as WMSSubLayer;
        //toggling a sublayer's visibility
        if ((highwayLayerWMSSub != null))
            bool visibility = highwayLayerWMSSub.IsVisible;
            highwayLayerWMSSub.SetVisibility(!visibility);
        //applying an existing style to a wms sub layer
        var pizzaLayerWMSSub = wmsLayers.Layers[0] as WMSSubLayer;
        var currentStyles = pizzaLayerWMSSub.GetStyleNames();
        pizzaLayerWMSSub.SetStyleName(currentStyles[1]);
    Inheritance Hierarchy
    System.Object
       ArcGIS.Desktop.Framework.Contracts.PropertyChangedBase
          ArcGIS.Desktop.Mapping.MapMember
             ArcGIS.Desktop.Mapping.Layer
                ArcGIS.Desktop.Mapping.CompositeLayer
                   ArcGIS.Desktop.Mapping.CompositeLayerWithTables
                      ArcGIS.Desktop.Mapping.ServiceLayer
                         ArcGIS.Desktop.Mapping.DynamicServiceLayer
                            ArcGIS.Desktop.Mapping.WMSLayer
    Requirements
