ArcGIS.Core.Geometry Namespace / Envelope Class
    Envelope Class Properties
    For a list of all members of this type, see Envelope members.
    Public Properties
     NameDescription
    Public Property Gets the area of this instance.
    Public PropertyGets the center of this instance as a MapPoint.
    Public PropertyGets the center of this instance as a Coordinate2D.
    Public Property Gets the depth of this instance.
    Public Property Gets the dimension of the geometry. (Inherited from ArcGIS.Core.Geometry.Geometry)
    Public PropertyOverridden.  Gets the minimum enclosing envelope of this instance. Returns null if this geometry has IsEmpty = true.
    Public PropertyOverridden. Gets the GeometryType of this instance. Always returns GeometryType.Envelope.
    Public Property Gets a value indicating if the geometry has ID. (Inherited from ArcGIS.Core.Geometry.Geometry)
    Public Property Gets a value indicating if the geometry has M. (Inherited from ArcGIS.Core.Geometry.Geometry)
    Public Property Gets a value indicating if the geometry has Z. (Inherited from ArcGIS.Core.Geometry.Geometry)
    Public Property Gets the height of this instance.
    Public Property Gets the ID maximum of this instance.
    Public Property Gets the ID minimum of this instance.
    Public PropertyOverridden.  Gets a value indicating whether or not the geometry is empty.
    Public PropertyIndicates whether this geometry is known to be M-simple. A geometry is M-simple if all the M-values are not NaN. False will be returned if GeometryEngine.IsMSimple has never been called. (Inherited from ArcGIS.Core.Geometry.Geometry)
    Public Property Indicates whether this geometry is known to be topologically consistent according to the geometry type for storage in a database. (Inherited from ArcGIS.Core.Geometry.Geometry)
    Public Property Indicates whether this geometry is known to be topologically consistent according to the Open Geospatial Consortium (OGC) validation specification. (Inherited from ArcGIS.Core.Geometry.Geometry)
    Public PropertyOverridden.  Gets the perimeter length of this instance.
    Public Property Gets the 3D length of the perimeter of this instance.
    Public Property Gets the M maximum of this instance.
    Public Property Gets the M minimum of this instance.
    Public PropertyOverridden.  Gets the point count of this instance. Always returns 5.
    Public PropertyGets the spatial reference of this instance. (Inherited from ArcGIS.Core.Geometry.Geometry)
    Public Property Gets the width of this instance.
    Public Property Gets the X maximum of this instance.
    Public Property Gets the X minimum of this instance.
    Public Property Gets the Y maximum of this instance.
    Public Property Gets the Y minimum of this instance.
    Public Property Gets the Z maximum of this instance.
    Public Property Gets the Z minimum of this instance.
    Top
