    ArcGIS.Desktop.Core Assembly
    Namespaces
    NamespaceDescription
    The ArcGIS.Desktop.Core namespace contains classes used to create and manage ArcGIS Pro projects. After creating or opening a project, developers can retrieve and work with the items it contains such as maps, layouts tasks, styles, and other resources. Developers can determine if changes to the current project are waiting to be saved, and set properties such as its home folder.
    This namespace contains types used for authentication.
    This namespace contains user controls.
    This namespace contains types for use with GPS/GNSS devices.
    This namespace contains events used with the DeviceLocation api.
    This namespace contains types used for ArcGIS Pro Global Events.
    The ArcGIS.Desktop.Core.Geoprocessing namespace exposes the ExecuteToolAsync method which can be used to execute any geoprocessing tools including those built by Esri and custom Python or ModelBuilder tools. All tools execute in the same way by accepting a set of parameters and returning a result task.
    This namespace contains classes and configuration types that are reserved for esri internal use only.
    This namespace contains classes for use with the portal API.
    This namespace contains classes for use with sharing.
    This namespace contains types used for Pro unit formats.
    This namespace contains types used for time zones.
