Overloads Sub Invalidate( _ ByVal relationship As Relationship _ )
void Invalidate( Relationship relationship )
Parameters
- relationship
- The relationship being modified.
await QueuedTask.Run(() =>
string message = String.Empty;
bool creationResult = false;
EditOperation editOperation = new EditOperation();
using (Geodatabase geodatabase = new Geodatabase(new DatabaseConnectionFile(new Uri("path\\to\\sde\\file\\sdefile.sde"))))
using (Table enterpriseTable = geodatabase.OpenDataset<Table>("LocalGovernment.GDB.piCIPCost"))
// Declare the callback here. We are not executing it .yet.
editOperation.Callback(context =>
TableDefinition tableDefinition = enterpriseTable.GetDefinition();
int assetNameIndex = tableDefinition.FindField("ASSETNA");
using (RowBuffer rowBuffer = enterpriseTable.CreateRowBuffer())
// Either the field index or the field name can be used in the indexer.
rowBuffer[assetNameIndex] = "wMain";
rowBuffer["COST"] = 700;
rowBuffer["ACTION"] = "Open Cut";
// subtype value for "Abandon".
rowBuffer[tableDefinition.GetSubtypeField()] = 3;
using (Row row = enterpriseTable.CreateRow(rowBuffer))
// To Indicate that the attribute table has to be updated.
context.Invalidate(row);
}, enterpriseTable);
try
creationResult = editOperation.Execute();
if (!creationResult) message = editOperation.ErrorMessage;
catch (GeodatabaseException exObj)
message = exObj.Message;
if (!string.IsNullOrEmpty(message))
Debug.WriteLine(message);
bool modificationResult = false;
QueryFilter openCutFilter = new QueryFilter { WhereClause = "ACTION = 'Open Cut'" };
using (RowCursor rowCursor = enterpriseTable.Search(openCutFilter, false))
int subtypeFieldIndex = tableDefinition.FindField(tableDefinition.GetSubtypeField());
while (rowCursor.MoveNext())
using (Row row = rowCursor.Current)
// In order to update the Map and/or the attribute table.
// Has to be called before any changes are made to the row.
row["ASSETNA"] = "wMainOpenCut";
if (Convert.ToDouble(row["COST"]) > 700)
// Abandon asset if cost is higher than 700 (if that is what you want to do).
row["ACTION"] = "Open Cut Abandon";
row[subtypeFieldIndex] = 3; //subtype value for "Abandon"
//After all the changes are done, persist it.
row.Store();
// Has to be called after the store too.
try
modificationResult = editOperation.Execute();
if (!modificationResult) message = editOperation.ErrorMessage;
