ArcGIS.Desktop.Editing Namespace / EditOperation Class / Merge Method / Merge(Layer,IEnumerable<Int64>,Inspector) Method
The layer of the features to merge.
The oids of the features to merge. The first feature in the list will be retained and contain the merge result.
An inspector that specifies the new attributes.
Example
    Merge features within a layer into an existing feature with attributes. The first feature in the sourceOIDs will be the feature that is retained and contain the merge result.
    Syntax
    Public Overloads Sub Merge( _
       ByVal sourceLayer As Layer, _
       ByVal sourceOIDs As IEnumerable(Of Long), _
       Optional ByVal inspector As Inspector _
    Parameters
    sourceLayer
    sourceOIDs
    inspector
    Exceptions
    ExceptionDescription
    Layer and sourceOIDs cannot be null. List of ObjectIDs cannot be empty.
    Example
    Edit Operation Merge Features
    // Merges multiple features from a source feature layer into a new feature, optionally using a template or inspector, and supports merging into a destination layer.
    await QueuedTask.Run(() =>
      var mergeFeatures = new EditOperation() { Name = "Merge Features" };
      //Merge three features into a new feature using defaults
      //defined in the current template
      mergeFeatures.Merge(currentTemplate as EditingRowTemplate, featureLayer, [10, 96, 12]);
      //Merge three features into a new feature in the destination layer
      mergeFeatures.Merge(destinationLayer, featureLayer, [10, 96, 12]);
      //Use an inspector to set the new attributes of the merged feature
      var inspector = new Inspector();
      inspector.Load(featureLayer, objectId);//base attributes on an existing feature
      inspector["NAME"] = "New name";
      inspector["DESCRIPTION"] = "New description";
      //Merge features into a new feature in the same layer using the
      //defaults set in the inspector
      mergeFeatures.Merge(featureLayer, [10, 96, 12], inspector);
      //Execute to execute the operation
      //Must be called within QueuedTask.Run
      if (!mergeFeatures.IsEmpty)
        //Execute and ExecuteAsync will return true if the operation was successful and false if not
        var result = mergeFeatures.Execute();
        //or use async flavor
        //await mergeFeatures.ExecuteAsync();
    Requirements
