ArcGIS.Desktop.Editing.Attributes Namespace / Inspector Class / AddAttributeAsync Method / AddAttributeAsync(String,MapMember,String,Boolean,String) Method
String specifying the field alias to be displayed
Layer or table to read schema from.
String specifying the field name or alias
If the string being passed is the alias
A tooltip to show
    Add an attribute to the feature inspector by mapmember, field name and/or field alias.
    Syntax
    Public Overloads Function AddAttributeAsync( _
       ByVal fieldAlias As String, _
       ByVal member As MapMember, _
       ByVal fieldNameOrAlias As String, _
       ByVal isAlias As Boolean, _
       ByVal tooltip As String _
    ) As Task(Of Attribute)
    Parameters
    fieldAlias
    member
    fieldNameOrAlias
    isAlias
    tooltip
    A tooltip to show
    Return Value
    A Task returning an attribute.
    Requirements
