ArcGIS.Desktop.Core Namespace / GeoprocessingOptions Class / SetAutoOpenMessagesWindow Method
Boolean indicating if the messages window will automatically open after running a tool in the Geoprocessing pane.
    Sets whether the messages window will automatically be opened after running a tool in the Geoprocessing pane. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    public void SetAutoOpenMessagesWindow(
       bool autoOpenMessagesWindow
    Public Sub SetAutoOpenMessagesWindow( _
       ByVal autoOpenMessagesWindow As Boolean _
    Parameters
    Exceptions
    ExceptionDescription
    Remarks
    Note: see ArcGIS.Desktop.Core.Geoprocessing.GPExecuteToolFlags for available options for modifying behavior of ArcGIS.Desktop.Core.Geoprocessing.Geoprocessing.ExecuteToolAsync. Changing these parameters modifies behavior of interactive GP tools
    Requirements
    ArcGIS Pro version: 3.1 or higher.
