Apply Complex Data Filter (Image Analyst Tools)
Summary
Smooths the phase component of the complex input synthetic aperture radar (SAR) data and outputs complex radar data.
Usage
  • The input must be complex data.
  • Higher alpha values will mean stronger filtering is applied. Using stronger filters will result in a smoother phase, but the accuracy is not necessarily improved.
    Using an alpha value that is too large can reduce the resolution of the output radar data.
    Using an alpha value that is too small can result in a noisy output.
  • The Goldstein Phase Filter option for the Filter Type parameter uses the outer window to compute phase variance. Phase variance is a type of coherence measurement. If the phase values in the outer window show high variability, which indicates low coherence, the smaller inner window will be used for filtering.
Parameters
Label Explanation Data type
Input Radar Data
The input complex radar data.
Raster Dataset; Raster Layer
Output Radar Data
The phase-filtered complex radar data.
Raster Dataset
Polarization Bands
(Optional)
The polarization bands that will be filtered.
The first band is selected by default.
String
Filter Type
(Optional)
The type of filter that will be applied.
  • Goldstein phase filter—A nonlinear adaptive algorithm that uses coherence to adapt the window size for optimal filtering will be applied. This is the default.
String
Alpha
(Optional)
The strength of the filtering that will be applied. The value range is from 0 to 1.0.
A value of 0 means no filtering will be applied. A value of 0.5 means a moderate filter will be applied. A value of 1 means maximum filtering will be applied.
The default value is 0.5.
Double
Inner Window Size
(Optional)
The inner filter window size. This window is used to filter phase values in high coherence areas. The default value is 8 pixels.
Long
Outer Window Size
(Optional)
The outer filter window size. This window is used to filter phase values in low coherence areas. The default values is 64 pixels.
Long
Environments
Cell Alignment, Cell Size, Compression, Current Workspace, Extent, Geographic Transformations, GPU ID, Match Multidimensional Variable, NoData, Output Coordinate System, Parallel Processing Factor, Processor Type, Pyramid, Raster Statistics, Resampling Method, Scratch Workspace, Snap Raster, Tile Size, Union Dimension
Licensing information
  • Basic: Requires Image Analyst
  • Standard: Requires Image Analyst
  • Advanced: Requires Image Analyst
