Apply Coregistration (Image Analyst Tools)
Summary
Resamples the secondary single look complex (SLC) data to the reference SLC grid using a digital elevation model (DEM) and orbit state vector metadata.
For Terrain Observation by Progressive Scan (TOPS) mode radar data, the tool also deramps and demodulates the secondary SLC before resampling. Once resampling is performed, the secondary radar data is reramped and remodulated.
Usage
  • For Sentinel-1 SLC data, use this tool after the Apply Orbit Correction tool.
  • For InSAR and DInSAR applications, the input radar data must have the same satellite geometry.
  • To optimize coregistration results, use the highest resolution DEM available for the area of interest.
  • Use the Compute Coherence tool to measure the success of the coregistration.
  • Baseline considerations for InSAR applications are shown in the following table:
    Baseline type
    Definition
    Smaller baseline
    Larger baseline
    Perpendicular baseline
    The component of the physical separation between the two satellite acquisition positions that is perpendicular to the line of sight (LOS).
    Preserves phase coherence, which is ideal for surface deformation monitoring. Sensitivity to elevation differences is reduced, making it less ideal for DEM generation.
    Increases sensitivity to topography, which is ideal for DEM generation.
    Temporal baseline
    The time separation between the two acquisitions.
    Better coherence in dynamic areas and captures rapid changes such as landslides and earthquakes.
    Suitable for detecting slow, cumulative deformation such as tectonic motion, although it carries a risk of decorrelation.
    Perpendicular and temporal baselines
Parameters
Label Explanation Data type
Input Reference Radar Data
The input reference complex radar data.
Raster Dataset; Raster Layer
Input Secondary Radar Data
The input secondary complex radar data.
Output Secondary Radar Data
The output secondary radar data coregistered to the reference radar data.
Raster Dataset
DEM Raster
(Optional)
The DEM raster that will be used to estimate the local illuminated area.
Mosaic Layer; Raster Layer
Apply geoid correction
(Optional)
Specifies whether the vertical reference system of the input DEM will be transformed to ellipsoidal height. Most elevation datasets are referenced to sea level orthometric height, so a correction is required in these cases to convert to ellipsoidal height.
  • Checked—A geoid correction will be made to convert orthometric height to ellipsoidal height (based on EGM96 geoid). This is the default.
  • Unchecked—No geoid correction will be made. Use this option only if the DEM is provided in ellipsoidal height.
Boolean
Polarization Bands
(Optional)
The polarization bands that will be corrected.
The first band is selected by default.
String
Environments
Cell Alignment, Compression, Current Workspace, NoData, Pyramid, Raster Statistics, Resampling Method, Scratch Workspace, Snap Raster, Tile Size
Licensing information
  • Basic: Requires Image Analyst
  • Standard: Requires Image Analyst
  • Advanced: Requires Image Analyst
