Classify Objects Using Deep Learning (Image Analyst Tools)
Summary
Runs a trained deep learning model on an input raster and an optional feature class to produce a feature class or table in which each input object or feature has an assigned class or category label.
This tool requires a model definition file containing trained model information. The model can be trained using the Train Deep Learning Model tool or by a third-party training software such as PyTorch. The model definition file can be an Esri model definition JSON file (.emd) or a deep learning model package, and it must contain the path to the Python raster function to be called to process each object and the path to the trained binary deep learning model file.
Usage
You must install the proper deep learning framework Python API in the ArcGIS Pro Python environment; otherwise, an error will occur when you add the Esri model definition file to the tool. The appropriate framework information should be provided by the person who created the Esri model definition file.
To set up your machine to use deep learning frameworks in ArcGIS Pro, see Install deep learning frameworks for ArcGIS.
This tool calls a third-party deep learning Python API and uses the specified Python raster function to process each object.
Sample use cases for this tool are available on the Esri Python raster function GitHub page. You can also write custom Python modules by following the examples and instructions.
The Model Definition parameter value can be an Esri model definition JSON file (
.emd), a JSON string, or a deep learning model package (.dlpk). A JSON string is useful when this tool is used on the server so you can paste the JSON string rather than upload the.emdfile. The.dlpkfile must be stored locally.The
CropSizeFixedproperty defines the crop mode of the raster tile around each object. A value of 1 means a fixed raster tile will be used, defined by theImageHeightandImageWidthproperties in the.emdfile. The object is centered within the fixed tile size. A value of 0 means a variable tile size will be used in which the raster tile is cropped using the smallest bounding box around the object.The
BlackenAroundFeatureproperty specifies whether the pixels that are outside each object will be masked. A value of 0 means the pixels outside of the object will not be masked. A value of 1 means the pixels outside of the object will be masked.The tool can process input imagery that is in map space or in pixel space. Imagery in map space is in a map-based coordinate system. Imagery in pixel space is based on rows and columns with no rotation and no distortion. The reference system can be specified when generating the training data in the Export Training Data For Deep Learning tool using the Reference System parameter. If the model is trained in a third-party training software, the reference system must be specified in the
.emdfile using theImageSpaceUsedparameter, which can be set toMAP_SPACEorPIXEL_SPACE.The input raster can be a single raster, multiple rasters, or a feature class with images attached. For more information about attachments, see Add or remove file attachments.
Increasing the batch size can improve tool performance; however, as the batch size increases, more memory is used. If an out of memory error occurs, use a smaller batch size. The
batch_sizevalue can be adjusted using the Arguments parameter.Batch sizes are square numbers, such as 1, 4, 9, 16, 25, 64 and so on. If the input value is not a perfect square, the highest possible square value is used. For example, if a value of 6 is specified, the batch size is set to 4.
Some deep learning models support Gradient-weighted Class Activation Mapping (Grad-CAM). The Grad-CAM method finds the gradient of the most dominant logit with respect to the latest activation map in the model. This method highlights the most influential pixels in the image that were instrumental in the model determining the classification of the image.
When Grad-CAM support is set to
truein the model definition, each feature in the output feature class will have an attachment that shows the influential pixels.This tool supports and uses multiple GPUs if available. To use a specific GPU, specify the GPU ID environment. When the GPU ID is not set, the tool uses all available GPUs. This is the default.
- When the Processor Type environment is set to CPU, and the Parallel Processing Factor environment is unspecified, the tool will use a Parallel Processing Factor value of 50%.
For information about requirements for running this tool and issues you may encounter, see Deep Learning frequently asked questions.
For more information about deep learning, see Deep learning using the ArcGIS Image Analyst extension.
Parameters
| Label | Explanation | Data type |
Input Raster |
The input image that will be used to classify objects. The input can be a single raster, multiple rasters in a mosaic dataset, an image service, a folder of images, or a feature class with image attachments. |
Raster Dataset; Raster Layer; Mosaic Layer; Image Service; Map Server; Map Server Layer; Internet Tiled Layer; Folder; Feature Layer; Feature Class |
Output Classified Objects Feature Class |
The output feature class that will contain geometries surrounding the objects or feature from the input feature class, as well as a field to store the categorization label. If the feature class already exists, the results will be appended to the existing feature class. |
Feature Class |
Model Definition |
The Model Definition parameter value can be an Esri model definition JSON file ( It contains the path to the deep learning binary model file, the path to the Python raster function to be used, and other parameters such as preferred tile size or padding. |
File; String |
Input Features (Optional) |
The point, line, or polygon input feature class that identifies the location of each object or feature to be classified and labelled. Each row in the input feature class represents a single object or feature. If no input feature class is provided, it is assumed that each input image contains a single object to be classified. If the input image or images use a spatial reference, the output from the tool is a feature class in which the extent of each image is used as the bounding geometry for each labelled feature class. If the input image or images are not spatially referenced, the output from the tool is a table containing the image ID values and the class labels for each image. |
Feature Class; Feature Layer |
Class Label Field (Optional) |
The name of the field that will contain the class or category label in the output feature class. If no field name is provided, a |
String |
Processing Mode (Optional) |
Specifies how all raster items in a mosaic dataset or an image service will be processed. This parameter is applied when the input raster is a mosaic dataset or an image service.
String |
Arguments (Optional) |
The information from the Model Definition parameter will be used to populate this parameter. These arguments vary, depending on the model architecture. The following are supported model arguments for models trained in ArcGIS. ArcGIS pretrained models and custom deep learning models may have additional arguments that the tool supports. Value table columns:
Value Table |
Caption (Optional) |
The name of the field that will contain the text or caption in the output feature class. This parameter is only supported when an Image Captioner model is used. If no field name is provided, a Note:This parameter will not appear in the Geoprocessing pane. To change the default field name, use the Class Label Field parameter. |
String |
Environments
Output Coordinate System, Geographic Transformations, Extent, Cell Size, Processor Type, GPU ID, Parallel Processing Factor
Licensing information
- Basic: Requires Image Analyst
- Standard: Requires Image Analyst
- Advanced: Requires Image Analyst
