Classify Raster Using Spectra (Image Analyst Tools)
Summary
Classifies a multiband raster dataset using spectral matching techniques. The input spectral data can be provided as a point feature class or a .json file.
Usage
  • If the input .json file contains spectral values that are provided as percent surface reflectance, the raster dataset must be rescaled using a sensor-specific scaling factor. For example, Landsat 8 and 9 collection 2 level-2 surface reflectance products can be rescaled to 0–1 using the following expression: Raster*0.0000275+(-0.2).
  • After applying scaling and offset factors, negative values can occur, especially over dark features such as water. These negative pixels must be masked before using the spectral information divergence (SID) classification method.
  • The order of the output classified raster follows the order of the input spectral profile.
  • The following is an example of a spectral profile provided as a .json file:
      "EsriEndmemberDefinitionFile" : 0,
      "FileVersion" : 1,
      "NumberOfEndmembers" : 4,
      "NumberOfBands" : 7,
      "Endmembers" : [
          "EndmemberID" : 1,
          "EndmemberName" : "basalt",
          "SpectralProfile" : [
                              0.076036952,
                              0.08137,
                              0.09371,
                              0.10768,
                              0.11076,
                              0.11424,
                              0.09824
          "EndmemberID" : 2,
          "EndmemberName" : "quartz",
                              0.75812,
                              0.77608,
                              0.80143,
                              0.81418,
                              0.82648,
                              0.85234,
                              0.86170
          "EndmemberID" : 3,
          "EndmemberName" : "salt deposits",
                              0.53381,
                              0.59598,
                              0.70402,
                              0.79024,
                              0.86628,
                              0.89397,
                              0.89507
          "EndmemberID" : 4,
          "EndmemberName" : "limestone",
                              0.15477,
                              0.16733,
                              0.19435,
                              0.21431,
                              0.24765,
                              0.32578,
                              0.32451
  • The point features require the following fields:
    • classname—A text field indicating the name of the class category
    • classvalue—A long integer field containing the integer value for each class category
  • An output Esri classifier definition file (.ecd) can be used as a input to the Classify Raster tool.
Parameters
Label Explanation Data type
Input Raster
The input multiband raster.
Mosaic Layer; Raster Layer; Image Service; String; Raster Dataset; Mosaic Dataset
Spectra or Points
The spectral information for different pixel classes.
A spectral library file (.esl) contain the spectral signatures for the classes, a training sample point feature class generated from the Training Samples Manager pane, or a .json file that contains the class spectral signatures.
Feature Layer; File; String
Method
Specifies the spectral matching method that will be used.
  • Spectral Angle Mapper—The vector angle between the input multiband raster and the reference spectra will be calculated in which the spectra of each pixel is treated as a vector. Angle values are in radians.
  • Spectral Information Divergence—The spectral information divergence between the input multiband raster and the reference spectra will be calculated. A score will be calculated for each pixel based on the divergence between the probability distributions of the pixel and the reference spectra. Values are in radians.
  • Spectral Information Divergence and Spectral Angle Mapper—The product of the Spectral Information Divergence score and the tangent of the Spectral Angle Mapper score will be calculated. This option has better discrimination capability compared to the SID and SAM options individually.
  • Normalized Spectral Similarity—The Normalized Spectral Similarity method will be calculated. This method calculates the spectral matching score from the Euclidean distance and the Spectral Angle Mapper score. This option has high discrimination capability but requires extensive reference data for high accuracy.
String
Thresholds
(Optional)
The threshold that will be used for spectral matching. Pixel values that exceed this value will be classified as undefined. This can be a single value applied to all spectral classes or a space-delimited list of values for each class.
String
Output Score Raster
(Optional)
A multiband raster that stores the matching results for each end member. The band order follows the order of the classes in the Spectra or Points parameter value. If the input is a multidimensional raster, the output format must be CRF.
Raster Dataset
Output Classifier Definition File
(Optional)
The output .ecd file.
File
Return value
Output Classified Raster
The output classified raster.
Raster
Environments
Cell Alignment, Cell Size, Compression, Current Workspace, Extent, Geographic Transformations, NoData, Output CONFIG Keyword, Output Coordinate System, Parallel Processing Factor, Pyramid, Raster Statistics, Resampling Method, Scratch Workspace, Snap Raster, Tile Size
Licensing information
  • Basic: Requires Image Analyst
  • Standard: Requires Image Analyst
  • Advanced: Requires Image Analyst
