Classify Raster (Image Analyst Tools)
Summary
Classifies a raster dataset based on an Esri classifier definition file (.ecd) and raster dataset inputs.
The .ecd file contains all the information needed to perform a specific type of Esri-supported classification. The inputs to this tool must match the inputs used to generate the required .ecd file.
The .ecd file can be generated from any of the classifier training tools, such as Train Random Trees Classifier or Train Support Vector Machine Classifier.
Usage
The input raster can be any Esri-supported raster and any valid bit depth.
The input
.ecdfile contains attribute statistics suitable for the appropriate classifier.To classify a time series of raster data using the Continuous Change Detection and Classification (CCDC) method, run the Analyze Changes Using CCDC tool to generate a change analysis raster. Use the change analysis raster and training sample data in the classifier training tools, and provide the resulting
.ecdfile and the change analysis raster as inputs to the Classify Raster tool.The output raster must be a
.crffile to support a multidimensional output.
Parameters
| Label | Explanation | Data type |
Input Raster |
The raster dataset to classify. |
Mosaic Layer; Raster Layer; Image Service; String; Raster Dataset; Mosaic Dataset |
Input Classifier Definition File |
The input Esri classifier definition file ( |
File |
Additional Input Raster (Optional) |
Ancillary raster datasets, such as a multispectral image or a DEM, will be incorporated to generate attributes and other required information for the classifier. This raster is necessary when calculating attributes such as mean or standard deviation. This parameter is optional. |
Return value
Output Classified Raster |
The path and name of the classified image you are creating. The output classified raster is defined by the input raster dataset and |
Raster |
Environments
Compression, Current Workspace, Extent, Geographic Transformations, NoData, Output CONFIG Keyword, Output Coordinate System, Parallel Processing Factor, Pyramid, Resampling Method, Raster Statistics, Scratch Workspace, Snap Raster, Tile Size
Licensing information
- Basic: Requires Image Analyst or Spatial Analyst
- Standard: Requires Image Analyst or Spatial Analyst
- Advanced: Requires Image Analyst or Spatial Analyst
