Calculating statistics for overlapping and non-overlapping neighborhoods
Available with Spatial Analyst license.
The neighborhood operations calculate output values by calculating a specified statistic to all the input cells that are contained in each neighborhood. The neighborhood is a moving window that iterates through the input data.
There are two basic kinds of neighborhood operations in Spatial Analyst: the operations where the neighborhoods of the processing locations overlap and those where the neighborhoods do not overlap.
The Focal Statistics tool processes the input dataset with overlapping neighborhoods. The Block Statistics tool processes data with neighborhoods that do not overlap.
Comparing Block vs. Focal neighborhoods
In the focal operation, only the processing cells receive the result of the calculation of all the cells in the neighborhood, whereas in the block operation, every cell within the minimum bounding rectangle that contains the neighborhood receives the same output value.
Neighborhood shape
The defined neighborhood shapes that can be specified are a rectangle of any dimension, a circle of any radius, an annulus (a doughnut shape) of any radius, and a wedge in any direction.
Neighborhood shapes
In addition to these geometric shapes, you can also create an irregularly shaped neighborhood, often called a kernel, where you can control exactly which cells in the neighborhood will be included in the calculations. Further, you can also apply different weights to specific cells in the neighborhood.
Example irregular and weighted kernel neighborhoods
Cells in the input raster that fall within the specified neighborhood will be included in the calculations being performed for that neighborhood.
For more specific information about how particular cells are included in a neighbourhood, refer to the individual tool reference topics, or see the following topics:
Types of neighborhood statistics
Various statistics can be computed on the cell values within the neighborhood being processed:
  • For Focal Statistics, the result of the calculation is applied only to locations corresponding to the processing cell on the output raster.
  • For Block Statistics, the result of the calculation is applied to all cells that are within the processing neighborhood.
Statistic
Majority
Determines the value that occurs most often in the neighborhood
Maximum
Determines the maximum value in the neighborhood
Mean
Computes the mean of the values in the neighborhood
Median
Computes the median of the values in the neighborhood
Minimum
Determines the minimum value in the neighborhood
Minority
Determines the value that occurs least often in the neighborhood
Percentile
Determines the specified percentile value of the cells in the neighborhood. This option is available for the Focal Statistics tool only.
Range
Determines the range of values in the neighborhood
Standard deviation
Computes the standard deviation of the values in the neighborhood
Sum
Computes the sum of the values in the neighborhood
Variety
Determines the number of unique values in the neighborhood
Neighborhood statistics
