Creating a cost surface raster
Available with Spatial Analyst license.
Legacy:
This functionality is deprecated and will be removed in a future release.
See Distance analysis and Migrate from legacy distance tools to distortion free distance tools for more information about the enhanced capabilities.
Cost distance tools calculate for each cell the least accumulative cost to specified source locations over a cost surface. A source and a cost dataset must first be created. These datasets can be created in different ways with the tools available in the ArcGIS Spatial Analyst extension.
Creating a multi criteria cost surface
In the following example, a least-cost path on which to construct a new road is needed. To create the path, first a cost distance surface must be created, which requires a source location dataset and a cost raster as inputs. The example will demonstrate creating a cost raster.
The source
The source is the starting point of your proposed feature for analysis. In the graphic below, you can see the area identified as the starting location (in red) for the proposed road.
The cost raster
A cost raster identifies the cost of traveling through each cell. To create this raster, you need to identify the cost of constructing a road through each cell. Although the cost raster is a single dataset, it is often used to represent several criteria. In this example, land use and slope influence the construction costs. Each of these datasets is in a different measurement system (land-use type and percent slope), so they cannot be directly compared to one another and must be reclassified to a common scale.
Creating a cost raster
In this example there are three general steps to create a cost raster.
Reclassifying your datasets to a common scale
The slope and land-use rasters have been reclassified on a scale of 1 to 10. The attributes of each dataset should be examined to determine their contribution to the cost of building a road. For example, it is more costly to traverse steep slopes, so steeper slopes will be assigned higher costs when reclassifying this dataset. The graphics below display the results.
Weighting datasets according to percent influence
The next step in producing the cost raster is to combine the reclassified datasets. The simplest approach is to just mathematically add them together. However, some factors may be more important than others. For instance, avoiding steep slopes may be twice as important as the land-use type, so you might give this dataset an influence of 66 percent and the land-use dataset an influence of 34 percent (to equal 100 percent). The following diagrams show the conceptual process:
Combining the datasets
The final cost raster is created by adding together the weighted datasets.
The following diagram shows the final cost raster. It is the result of reclassifying the input datasets of slope and land use; weighting each by 0.66 and 0.34, respectively; then combining the weighted datasets.
This cost surface raster can now be used as an input into the Cost Distance or other cost tools.
