Understanding cost distance analysis
Available with Spatial Analyst license.
Legacy:
This functionality is deprecated and will be removed in a future release.
See Distance analysis and Migrate from legacy distance tools to distortion free distance tools for more information about the enhanced capabilities.
From the cell perspective, the objective of the cost tools is to determine the least costly path to reach a source for each cell location in the Analysis window. The least-accumulative cost to a source, the source that allows for the least-cost path, and the least-cost path itself must be determined for each cell.
The cost distance tools are similar to Euclidean tools, but instead of calculating the actual distance from one location to another, the cost distance tools determine the shortest weighted distance (or accumulated travel cost) from each cell to the nearest source location. These tools apply distance in cost units, not in geographic units.
The cost distance tools are the following:
  • Cost Distance gives the distance to the nearest source for each cell in the raster, based on the least-accumulative cost over a cost surface.
  • Cost Back Link gives the neighbor that is the next cell on the least-accumulative cost path to the nearest source.
  • Cost Allocation gives the nearest source for each cell, based on the least-accumulative cost over a cost surface.
  • Cost Path gives the path with the least cost from a source to a destination.
  • Cost Connectivity gives the least-cost connectivity network between two or more input regions.
All cost distance tools require both a source dataset and a cost raster as input.
Cost distance outputs
The different types of output from the cost distance tools are described in the following sections.
Distance output
The output from the Cost Distance tool records the accumulated cost of getting from each cell to the nearest source.
For example, consider the following source locations, identified as values 1 and 2 in the diagram:
Input source locations
The accumulated least costly way of getting from source cell 1 (dark orange) to the destination (the school icon) is 10.5.
The tool calculates a value for each cell
Cost-weighted distance calculated for each cell
Back-link direction output
While the output cost-distance raster identifies the accumulative cost for each cell to return to the closest source location, it does not show which source cell to return to or how to get there. The Cost Back Link tool returns a direction raster as output, providing what is essentially a road map that identifies the route to take from any cell, along the least-cost path, back to the nearest source.
The algorithm for computing the back-link raster assigns a code to each cell. The code is a sequence of integers from 0 to 8. The value 0 is used to represent the source locations, since they have essentially already reached the goal (the source). The values 1 through 8 encode the direction in a clockwise manner starting from the right. Following is the default symbology applied to the directional output, accompanied by an arrow diagram matching directional arrows to the color symbology:
Direction coding Directionality
For example, if an output cell is assigned the value 5 as part of the least-cost path to a source, the path should move to the neighboring cell on the left. If that cell has 7, the path should move due north, and so on.
From the example in the previous section, the cheapest way to get from the cell with a value of 10.5 to the source (the school site) is to go diagonally through the cell with a value of 5.7. The back-link raster shows the travel direction from each cell to the nearest source.
Cost-weighted distance Cost back-link output
The direction algorithm assigns a value of 4 to the cell with a value of 10.5 and 4 to the cell with a value of 5.7, because (from the directional coding described above) this is the direction of the least-cost path back to the source from each of these cells.
This process is done for all cells in the output back-link raster, producing an output that tells you the direction to travel from every cell in the cost-distance raster back to the source.
Cost-weighted distance example Cost-weighted direction example
If you want to calculate the least-cost (shortest) path between source locations and destination locations, both the cost-distance and cost back-link rasters will be required.
Allocation output
The output from the Cost Allocation tool identifies the nearest source each cell is allocated to. It is conceptually similar to the output from the Euclidean Allocation tool, with the difference that nearness is expressed in terms of accumulated travel cost.
Nearest source cell is identified
Nearest source cell is identified.
Optional outputs
In addition to the specific output raster from each tool, the cost tools can also optionally create other types of cost outputs. The Cost Distance tool can create a cost back-link raster, and the Cost Back Link tool a cost-distance raster. The Cost Allocation tool can create both the distance and back-link rasters. This is useful if you want to create other outputs from the execution of a single tool.
Cost Path tool
Once the accumulative cost and back-link rasters are created, least-cost path routes can be derived from any designated destination cell or zones. The Cost Path tool retraces the destination cells through the back-link raster to a source.
Cost Connectivity
The Cost Connectivity tool creates the least-cost network between the input regions. Even though this tool applies the same concepts described above, it creates the network from the input regions and the cost surface in a single step.
Cost distance inputs
Source input
If the source dataset is a raster, it may contain single or multiple zones. These zones may or may not be connected. All cells that have a value (including 0) are processed as source cells. All non-source cells must be assigned NoData in the source raster. The original values assigned to the source locations (raster or feature) are retained.
If the source dataset is a feature dataset, it will be converted internally to a raster at the resolution determined by the environment; if the resolution is not explicitly set there, it will be the same as the input cost raster. If the source data is a raster, the cell size of that raster will be used. From this point forward, this documentation will assume that feature source data has been converted to raster.
There is no inherent limit to the number of sources in the input raster or feature source data.
Cost input
The cost raster can be a single raster and is generally the result of the composite of multiple rasters. The units assigned to the cost raster can be any type of cost desired: dollar cost, time, energy expended, or a unitless system that derives its meaning relative to the cost assigned to other cells. The values on the input cost raster can be integer or floating point, but they cannot be negative or 0 (you cannot have a negative or zero cost). The cost raster cannot contain values of 0 since the algorithm is a multiplicative process.
Tip:
If your cost raster does contain values of 0, and these values represent areas of lowest cost, change these values to a small positive value (such as 0.01) before running Cost Distance. You can do this with the Con tool. If areas with a value of 0 represent areas that should be excluded from the analysis, these values should be turned to NoData before running Cost Distance, by first running Set Null.
How cost distance is calculated
For more information on how cost distance is calculated, see the following section.
