Radial Roughness (Spatial Analyst Tools)
Summary
Calculates a radial roughness index value for each cell of a raster surface.
Learn more about how Radial Roughness works
Usage
  • The output roughness values calculated by this tool are decoupled from the effect of the local slope. A sloping terrain can have a low roughness value if its surface is smooth.
  • This tool uses a 5-by-5-cell moving window to process the data. If any cell in the moving window is NoData, the output for the current processing cell will be NoData.
  • The cells in the outermost two rows and columns of the output raster will be NoData. This is because along the boundary of the input dataset, those cells do not have enough valid neighbors.
  • This tool supports parallel processing. If your computer has multiple processors or processors with multiple cores, better performance may be achieved, particularly on larger datasets. The Parallel processing with Spatial Analyst help topic includes details about this capability and how to configure it.
  • When the output raster format is a .crf file, this tool supports the Pyramid raster storage environment. Pyramids will be created in the output by default. For any other output format, this environment is not supported, and pyramids will not be created.
  • See Analysis environments and Spatial Analyst for additional details about the geoprocessing environments that apply to this tool.
Parameters
Label Explanation Data type
Input Surface Raster
The input surface raster.
Raster Layer
Return value
Output Raster
The output roughness raster.
It will be floating-point type.
Raster
Environments
Auto Commit, Cell Size, Cell Size Projection Method, Compression, Current Workspace, Extent, Geographic Transformations, Mask, Output CONFIG Keyword, Output Coordinate System, Parallel Processing Factor, Pyramid, Scratch Workspace, Snap Raster, Tile Size
Licensing information
  • Basic: Requires Spatial Analyst
  • Standard: Requires Spatial Analyst
  • Advanced: Requires Spatial Analyst
References
See the following references for additional information:
