An overview of the Generalization toolset
The Generalization toolset contains tools that generalize data for different geometry types.
Tool |
Description |
Eliminates a polygon by merging it with the polygon from the surrounding features that it shares the longest boundary with. |
Exports data generalized by the ArcGIS Topographic Mapping theme-based generalization models into a production schema using generalization rules defined in a Microsoft Excel spreadsheet. |
Fills gaps between polygon features that participate in a topology where the coincident boundaries are evident. |
Splits a polygon based on its width and classifies each portion as narrow or wide based on its width and length. |
Imports data from a production schema to a themed generalization database using generalization rules defined in a Microsoft Excel spreadsheet. |
Creates centerlines from polygon features. This tool is useful for creating centerlines from hydrographic polygons for use at smaller scales. |
Removes lines that are shorter than a specified minimum length and do not connect to other features on one end. |
Sets the direction of line segments to match the slope direction of underlying elevation features. The direction of a line is used by some of the generalization and cartography tools. |
Generates a simplified hydrographic line network for display at a smaller scale. The resulting hydrographic network maintains the main arteries while thinning less significant features based on hierarchy, length, and spacing between features. |
