Introduction to ArcGIS StoryMaps
ArcGIS StoryMaps is a web-based content-creation and communication tool that allows you to share maps, apps, and multimedia in the context of a narrative.
What you can create
You can use ArcGIS StoryMaps to create the following types of items:
Type Description
Stories Create immersive, engaging stories. Stories can include maps, narrative text, lists, images, videos, embedded items, and other media.
Briefings Build dynamic presentations with briefings. Seamlessly integrate live maps, real-time data, multimedia, and more within a slide-based format.
Frames Produce short-form stories called frames. Create mobile-first, short stories optimized for sharing and quick consumption.
Collections Assemble collections. Collections can include ArcGIS StoryMaps and other ArcGIS content—such as dashboards, instant apps, and Survey123 forms—all bundled together for faster sharing.
Themes Design themes. Themes allow you to apply a reusable set of colors, fonts, and other style elements to your stories, briefings, and collections.
What else you can do
You can also use ArcGIS StoryMaps to do the following:
Activity Description
Publish and share content Published ArcGIS StoryMaps items can be shared within your organization, to specific groups, or with everyone.
Manage your content On the ArcGIS StoryMaps content page, you can view and edit your ArcGIS StoryMaps items and find content authored by others in your organization.
Collaborate with others Co-author ArcGIS StoryMaps content with others in your ArcGIS organization through groups or use templates to capture and share common storytelling patterns.
Capabilities
There are numerous capabilities you can use when authoring content with ArcGIS StoryMaps:
Capability Details
Interactive builders ArcGIS StoryMaps provides a single authoring experience that allows you the flexibility to create content with a variety of media in several formats.
Enhanced support for ArcGIS maps and apps You can configure the appearance and behavior of 2D web maps and 3D web scenes without leaving the ArcGIS StoryMaps builders and embed ArcGIS apps created by other members of your organization.
Express maps Simplified maps, created in the ArcGIS StoryMaps builders, add basic geographic context to your narrative.
One-click themes Quickly change the look and feel of your content with a selection of professionally designed themes, or create your own theme in minutes.
Publishing workflow Changes are automatically saved as you work. After publishing an ArcGIS StoryMaps item, you can make revisions without affecting the version you shared with others. When you are ready, republish it to make your changes visible.
Mobile-first design The modern design of ArcGIS StoryMaps is optimized for viewing on any screen size.
Social sharing Share published ArcGIS StoryMaps items and display them as formatted cards on social networks.
Related topics
