Business Analyst toolbox history
Disponible con licencia de Business Analyst.
En las tablas de abajo se muestra un catálogo de los cambios realizados en todas las herramientas de la caja de herramientas. Hay una tabla por herramientas y puede hacer clic en el nombre de la herramienta para ir a la página de referencia correspondiente.
Para obtener más información sobre el modo de interpretar y usar estas tablas, consulte Temas de historial de caja de herramientas.
Version |
Description |
2.2 |
New at this version |
Version |
Description |
2.2 |
Version |
Description |
2.2 |
Version |
Description |
2.6 |
Version |
Description |
2.6 |
Version |
Description |
2.6 |
Version |
Description |
2.3 |
Version |
Description |
2.2 |
Version |
Description |
3.7 |
Parameter |
3.5 |
3 new parameters added:
Parameter |
3.4 |
New parameter added: |
3.3 |
4 new parameters added:
Parameter |
2.2 |
License changed from New parameter added: Parameter removed: |
2.1 |
Version |
Description |
2.6 |
Version |
Description |
3.0 |
New environment added: |
2.2 |
License changed from Required Extension changed from 2 parameters removed:
Parameter order changed at parameter 3:
2.1 |
Version |
Description |
2.6 |
Version |
Description |
3.0 |
2.8 |
Version |
Description |
2.7 |
Generate Customer Demographic Profile Report
Version |
Description |
3.7 |
Version |
Description |
2.7 |
2 new parameters added:
2.6 |
8 new parameters added:
Parameter
2.2 |
License changed from |
2.1 |
Version |
Description |
3.7 |
Version |
Description |
2.5 |
Version |
Description |
2.9 |
5 new parameters added:
2.2 |
Version |
Description |
3.0 |
2.7 |
Parameter |
2.4 |
Version |
Description |
3.0 |
2.3 |
Version |
Description |
3.2 |
3.0 |
Version |
Description |
2.5 |
Version |
Description |
3.5 |
3.3 |
3.2 |
Default value for parameter |
2.7 |
2.4 |
Version |
Description |
2.6 |
Version |
Description |
2.5 |
Version |
Description |
2.2 |
Version |
Description |
2.6 |
Version |
Description |
2.6 |
Version |
Description |
2.5 |
Version |
Description |
2.5 |
Version |
Description |
2.5 |
Version |
Description |
3.0 |
2.7 |
Parameter |
2.6 |
2.5 |
Version |
Description |
3.0 |
New environment added: 2 new parameters added:
2.7 |
Parameter |
2.5 |
Version |
Description |
3.0 |
2.7 |
Parameter |
2.6 |
2.3 |
Version |
Description |
2.4 |
Version |
Description |
2.5 |
Version |
Description |
3.1 |
Version |
Description |
2.6 |
Version |
Description |
2.6 |
Version |
Description |
3.4 |
2.2 |
Version |
Description |
3.0 |
2.5 |
Version |
Description |
2.3 |
Version |
Description |
2.7 |
Parameter |
2.6 |
Version |
Description |
2.7 |
Version |
Description |
3.4 |
2.2 |
Version |
Description |
3.4 |
Version |
Description |
3.5 |
3.2 |
3.0 |
2.9 |
2.2 |
License changed from Default value for parameter |
2.1 |
