& (Boolean And) operator
サマリー
Performs a Boolean And operation on the cell values of two input rasters.
Boolean And illustration
OutRas = Raster("InRas1") & Raster("InRas2")
ディスカッション
The & operator will perform a Boolean And operation when one or more input (operand) is a raster. If both inputs (operands) are numbers, then the & operator will perform Bitwise And operation. For more information on how to work with operators, see Working with operators.
When there are multiple operators in an expression, the operators are not necessarily run in left-to-right order. The operator with the highest precedence value will be run first. For more information, see the operator precedence table in Work with operators in map algebra. Use parentheses to control the run order.
Boolean (~, &, ^, |) operators have a higher precedence level than Relational (<, <=, >, >=, ==, !=) operators. When Boolean operators are used in the same expression as Relational operators, the Boolean operators will be run first. To change the order the operators are run, use parentheses.
When multiple Relational or Boolean operators are used consecutively in a single expression, the expression may fail to run in some cases. To avoid this, use appropriate parentheses in the expression so that the run order of the operators is explicitly defined. For more information, see Complex statement rules.
Two inputs are necessary for the Boolean evaluation to take place.
The order of the input is irrelevant for this operator.
If the input values are floating point, they are converted to integer values by truncation before the Boolean operation is performed. The output values are always integer.
Another way to perform the Boolean And operation is a &= b which is an alternative way to write a = a & b.
If both inputs are single-band rasters, or one of the inputs is a constant, the output will be a single-band raster.
If both inputs are multiband rasters, the operator will perform the operation on each band from one input, and the output will be a multiband raster. The number of bands in each multiband input must be the same.
If one of the inputs is a multiband raster and the other input is a constant, the operator will perform the operation using the constant value for each band in the multiband input, and the output will be a multiband raster.
If both inputs are multidimensional rasters with the same number of variables, the operator will perform the operation for all slices with the same dimension value, and the output will be a multidimensional raster. The variables in the inputs must have the same dimensions or a common dimension but no uncommon dimensions.
If both inputs have one variable but different names, set the Match Multidimensional Variable environment to False to perform the operation.
If one of the inputs is a multidimensional raster and the other input is a constant, the operator will perform the operation for all slices for all variables using the constant value, and the output will be a multidimensional raster.
オペランド
オペランド 説明 データ タイプ
in_raster_or_constant1
The first input to use in the Boolean And operation.
If one of the inputs is a raster and the other is a scalar, an output raster will be created with the evaluation being performed for each cell in the input raster.
Raster Layer | Constant
in_raster_or_constant2
The second input to use in the Boolean And operation.
環境
Cell Size, Current Workspace, Mask, Output Coordinate System, Extent, Scratch Workspace, Snap Raster
コードのサンプル
& (Boolean And) example 1 (Python window)
This sample performs a Boolean And operation on two input rasters.
import arcpy
from arcpy import env
from arcpy.ia import *
env.workspace = "C:/iapyexamples/data"
outBooleanAnd = Raster("degs") & Raster("negs")
outBooleanAnd.save("C:/iapyexamples/output/outbooland.img")
& (Boolean And) example 2 (stand-alone script)
# Name: Op_BooleanAnd_Ex_02.py
# Description: Performs a Boolean And operation on the cell values
#              of two input rasters
# Requirements: Image Analyst extension
# Import system modules
import arcpy
# Set environment settings
# Set local variables
inRaster1 = Raster("degs")
inRaster2 = Raster("negs")
# Run BooleanAnd
outBooleanAnd = inRaster1 & inRaster2
# Save the output
outBooleanAnd.save("C:/iapyexamples/output/outbooland")
