Reclass geoprocessing functions
Spatial Analyst ライセンスで利用可能。
3D Analyst ライセンスで利用可能。
The Reclass geoprocessing functions provide a variety of methods that allow you to reclassify or change input cell values to alternative values.
The most common reasons for reclassifying data are to accomplish the following:
  • Replace values based on new information.
  • Group certain values.
  • Reclassify values to a common scale (for example, for use in a suitability analysis or for creating a cost raster for use in the Cost Distance geoprocessing function).
  • Set specific values to NoData or set NoData cells to a value.
  • Learn more about reclassification
There are several approaches to reclassifying your data. The methods of reclassification and the geoprocessing functions that perform them are:
  • Individual values. (Lookup, Reclassify)
  • Ranges of values. (Reclass by ASCII File, Reclass by Table, Reclassify)
  • Intervals. (Slice)
  • Continuous values using functions. (Rescale by Function)
The following topics provide background information on the theoretical aspects of these geoprocessing functions as well as some examples of their implementation.
The following table lists the available geoprocessing functions and provides a brief description of each.
Geoprocessing Function
Lookup
Creates a raster by looking up values in another field in the table of the input raster.
Reclassifies (or changes) the values of the input cells of a raster using an ASCII remap file.
Reclass by Table
Reclassifies (or changes) the values of the input cells of a raster using a remap table.
Reclassify
Reclassifies (or changes) the values in a raster.
Rescale by Function
Rescales the input raster values by applying a selected transformation function and transforming the resulting values onto a specified continuous evaluation scale.
Slice
Slices or reclassifies the range of values of the input cells into zones (classes). The available data classification methods are equal interval, equal area (quantile), natural breaks, standard deviation (mean-centered), standard deviation (mean as a break), defined interval, and geometric interval.
Geoprocessing functions in the Reclass category
