# Name: GlobalPolynomialInterpolation_Example_02.py
# Description: Global Polynomial interpolation fits a smooth surface that is
# defined by a mathematical function (a polynomial) to the input
# sample points. The Global Polynomial surface changes gradually
# and captures coarse-scale pattern in the data. Global Polynomial
# interpolation is like taking a piece of paper and fitting it
# between the raised points (raised to the height of value).
# Requirements: Geostatistical Analyst extension
# Import system modules
import arcpy
# Set environment settings
arcpy.env.workspace = "C:/gapyexamples/data"
# Set local variables
inPointFeatures = "ca_ozone_pts.shp"
zField = "ozone"
outLayer = "outGPI"
outRaster = "C:/gapyexamples/output/gpiout"
cellSize = 2000.0
power = 2
# Run GlobalPolynomialInterpolation
arcpy.ga.GlobalPolynomialInterpolation(inPointFeatures, zField, outLayer,
outRaster, cellSize, power)
