// (Integer Division) operator
Zusammenfassung
Performs an integer divide on the values of two rasters on a cell-by-cell basis.
Divide illustration
OutRas = Raster("InRas1") // Raster("InRas2")
Diskussion
When using an operator with a raster input, the result will be a raster. However, if all inputs are numbers, the result will be a number.
When there are multiple operators in an expression, the operators are not necessarily run in left-to-right order. The operator with the highest precedence value will be run first. For more information, see the operator precedence table in Work with operators in map algebra. Use parentheses to control the run order.
The order of the input is relevant for this operator.
When a number is divided by zero, the output result is NoData.
If both inputs are integers, the output contains integer values. For example, if 5 is divided by 2, the output will be 2 (the remainder is discarded).
If either input is of floating-point type, the output quotient will be floating-point. For example, if 5.3 is divided by 2, the output is 2.0 (the remainder of 0.65 is discarded).
Another way to perform the integer divide operation is a //= b, which is an alternative way to write a = a // b.
If both inputs are single-band rasters, or one of the inputs is a constant, the output will be a single-band raster.
If both inputs are multiband rasters, the operator will perform the operation on each band from one input, and the output will be a multiband raster. The number of bands in each multiband input must be the same.
If one of the inputs is a multiband raster and the other input is a constant, the operator will perform the operation using the constant value for each band in the multiband input, and the output will be a multiband raster.
If both inputs are multidimensional rasters with the same number of variables, the operator will perform the operation for all slices with the same dimension value, and the output will be a multidimensional raster. The variables in the inputs must have the same dimensions or a common dimension but no uncommon dimensions.
If both inputs have one variable but different names, set the Match Multidimensional Variable environment to False to perform the operation.
If one of the inputs is a multidimensional raster and the other input is a constant, the operator will perform the operation for all slices for all variables using the constant value, and the output will be a multidimensional raster.
Operanden
Operand Erläuterung Datentyp
in_raster_or_constant1
The input whose values will be divided by the second input.
If the first input is a raster and the second is a scalar, an output raster is created with each input raster value being divided by the scalar value.
Raster Layer | Constant
in_raster_or_constant2
The input whose values the first input are to be divided by.
If the first input is a scalar and the second is a raster, an output raster is created with each input raster value being divided into the scalar value.
Umgebungen
Cell Size, Current Workspace, Mask, Output Coordinate System, Extent, Scratch Workspace, Snap Raster
Codebeispiel
// (Integer Division) example 1 (Python window)
This sample divides the values of the first input raster by the second.
import arcpy
from arcpy import env
from arcpy.sa import *
env.workspace = "C:/sapyexamples/data"
outDivide = Raster("degs") // Raster("negs")
outDivide.save("C:/sapyexamples/output/outdivide")
// (Integer Division) example 2 (stand-alone script)
# Name: Op_IntegerDivide_Ex_02.py
# Description: Divides the values of two rasters on a cell-by-cell basis
# Requirements: Spatial Analyst extension
# Import system modules
import arcpy
# Set environment settings
# Set local variables
inRaster01 = Raster("elevation")
inRaster02 = Raster("landuse")
# Run Integer Divide
outDivide = inRaster01 // inRaster02
# Save the output
outDivide.save("C:/sapyexamples/output/outdivide2")
