Topographic Production toolbox history
In den nachfolgenden Tabellen sind die Änderungen aufgeführt, die an den Werkzeugen der Toolbox vorgenommen wurden. Für jedes Werkzeug ist eine eigene Tabelle verfügbar. Klicken Sie auf den Namen des Werkzeugs, um zur Referenzseite des Werkzeugs zu gelangen.
Weitere Informationen zum Interpretieren und Verwenden dieser Tabellen finden Sie unter Themen zur Änderungshistorie von Toolboxes.
Apply Building Offsets
Version
3.6
Required Extension changed to Topographic Mapping
2.4
New at this version
Apply Element Values
Version
3.6
New at this version
Apply Feature Level Metadata
Version
3.6
3.0
New at this version
Apply Masks From Rules
Version
3.6
2.3
New at this version
Apply Visual Specification to Map
Version
3.6
2.3
New at this version
Calculate Bridge Offsets
Version
3.6
2.6
Default value for parameter min_length changed from 1.35 Millimeters to 1.5 Millimeters
2.2
New at this version
Calculate Default Values
Version
3.6
2.0
New at this version
Calculate Magnetic Components
Version
3.6
3.5
New parameter added: wmm_file
2.7
New at this version
Calculate Max Elevation Figures
Version
3.6
2.9
New at this version
Calculate Metrics
Version
3.6
3.4
New parameter added: only_populate_null_values
3.2
New parameter added: elevation_raster
3.0
2 new parameters added:
  • mgrs_precision
  • mgrs_attributes
Parameter in_metric_types had new option added: MGRS
Default value for parameter in_metric_types changed from LENGTH;WIDTH;AREA;ANGLE_OF_ORIENTATION;ELEVATION to LENGTH;WIDTH;AREA;ANGLE_OF_ORIENTATION;ELEVATION;MGRS
2.0
New at this version
Cancel Remaining Tasks
Version
3.6
3.5
This tool has been removed due to its integration with Workflow Manager (Classic), which is now deprecated.
3.0
New at this version
Copy Extended Properties
Version
3.6
3.5
2.5
New at this version
Copy Job Files
Version
3.6
3.5
2.5
New at this version
Create Cross-Reference Geodatabase
Version
3.6
2.9
New at this version
Create Job For Task
Version
3.6
3.5
2.3
New at this version
Create Task Group Jobs
Version
3.6
3.5
2.9
New at this version
Download Job Files
Version
3.6
New at this version
Eliminate Polygon
Version
3.6
2.1
New at this version
Export Generalized Data
Version
3.6
2.3
New at this version
Export MGCP Metadata
Version
3.6
2.0
New at this version
Export Topology
Version
3.6
2.0
New at this version
Extract Data By Feature
Version
3.6
2.8
  • excluded_rel_classes
  • where_clause
2.6
  • get_related_data
  • expand_feature_classes_and_tables
2.5
New at this version
Fill Gaps
Version
3.6
2.4
New at this version
GAIT
Version
3.6
3.5
New parameter added: out_gaitlayer
2.0
New at this version
Generate Adjoining Sheets Features
Version
3.6
3.4
New parameter added: buffer_size
Parameter scale had new option added: None
2.1
New at this version
Generate Elevation Bands
Version
3.6
2.6
Parameter in_raster has new data type: Mosaic Layer
2.3
Parameter in_aoi has new data type: Layer
Parameter in_aoi had data type removed: Feature Layer
2.1
New at this version
Generate Elevation Bands From Features
Version
3.6
2.9
New at this version
Generate Elevation Guide Features
Version
3.6
3.3
New parameter added: min_island_area
2.6
Parameter in_rasters has new data type: Mosaic Layer
2.2
New at this version
Generate Excel From Geodatabase
Version
3.6
3.0
New at this version
Generate Geodatabase From Excel
Version
3.6
3.0
New at this version
Generate Isogonic Lines
Version
3.6
3.4
New at this version
Generate Location Diagram Features
Version
3.6
3.3
3.2
9 new parameters added:
  • hydroline_minspacing
  • hydroarea_minlength
  • hydroarea_minwidth
  • hydroline_minlength
  • smooth_tolerance
  • specification
  • hydro_area_features
  • tpc_features
  • hydro_line_features
2.9
New at this version
Generate Product Layout
Version
3.6
3.2
Parameter output_type had new option added: PPKX
3.0
  • output_type
  • export_file
2.6
New at this version
Generate Spot Heights
Version
3.6
2.9
  • scale
  • z_factor
2.6
2.4
Parameter spot_height_subtype changed from Required to Optional
2.2
New at this version
Generate Topographic Contours
Version
3.6
3.2
4 new parameters added:
  • half_auxiliary_code
  • depression_auxiliary_code
  • supplemental_contours
  • quarter_auxiliary_code
2.5
Parameter order changed at parameter 4:
  • Old parameter: contour_subtype
  • New parameter: elevation_field
Parameter scale changed from Required to Optional
Parameter resample_raster changed from Required to Optional
2.4
New at this version
Geodatabase To Shape
Version
3.6
3.0
Parameter conversion_method had new option added: MUVD
2.0
New at this version
GeoNames To Geodatabase
Version
3.6
3.3
New parameter added: match_fields
2.0
New at this version
Get Features By Job AOI
Version
3.5
2.7
Parameter filter_feature has new data type: Feature Layer
Parameter filter_feature had data type removed: Layer
2.5
New at this version
Import MGCP Metadata
Version
3.6
2.0
New at this version
Import Topology
Version
3.6
2.0
New at this version
Identify Contours
Version
3.6
3.2
6 new parameters added:
  • contour_interval
  • base_contour
3.1
  • area_of_interest
  • z_factor
3.0
New parameter added: depression_contours_count
2.6
2.2
New at this version
Identify Narrow Polygons
Version
3.6
2.3
New parameter added: connecting_features
2.1
New at this version
Import Generalization Data
Version
3.6
2.3
New at this version
Insert Task Group
Version
3.5
2.3
New at this version
Load Data
Version
3.6
2.0
New at this version
Make Grids And Graticules Layer
Version
3.6
2.2
New at this version
Make Masks From Rules
Version
3.6
2.3
New at this version
Merge Lines By Pseudo Node
Version
3.6
2.9
New at this version
Polygon To Centerline
Version
3.6
2.3
2.1
New at this version
Populate Map Sheet Info
Version
3.6
2.2
New at this version
Remove Cutback Vertices
Version
3.6
2.1
New at this version
Remove Small Lines
Version
3.6
2.3
License changed from Advanced to Standard
New parameter added: split_input_lines
2.1
New at this version
Repair Self Intersection
Version
3.6
2.2
2.1
New at this version
Set Data Workspace
Version
3.6
3.5
2.3
New at this version
Set Line Direction
Version
3.6
3.2
New at this version
Set Next Task
Version
3.6
3.5
2.3
New at this version
Set Production Properties
Version
3.6
3.5
2.3
New at this version
Set Task Group Dependencies
Version
3.6
3.5
2.9
New at this version
Set Task List
Version
3.6
3.5
2.3
New at this version
Set Task Status
Version
3.6
3.5
3.1
Parameter status had new option added: RESTART
2.3
New at this version
Split Features
Version
3.6
2.0
New at this version
Thin Hydrology Lines
Version
3.6
2.1
New at this version
Thin Spot Heights
Version
3.6
2.4
New at this version
Unzip MGCP Cell And Import
Version
3.6
2.0
New at this version
Update Extended Property
Version
3.5
2.5
New at this version
Update GeoNames
Version
3.6
2.0
New at this version
Update Property Count
Version
3.5
2.6
Deprecated at this version. Replacement functionality in Update Extended Property.
2.3
New at this version
Update Task Group Metrics
Version
3.5
2.6
New at this version
Update Topographic Production Service Database
Version
3.6
New at this version
Upload Job Files
Version
3.6
New at this version
Validate Spot Heights
Version
3.6
3.2
New parameter added: use_rasters
3.1
New at this version
