Work with Knowledge Studio projects
In ArcGIS Knowledge Studio, your work is organized in projects. A Knowledge Studio project is a workspace for exploring and analyzing knowledge graph data. Each Knowledge Studio project includes a reference to the knowledge graph, a knowledge graph view, a query view, and a dashboard view. The project can also reference maps, link charts, and data cards.
Project views
All Knowledge Studio projects include a knowledge graph view, query view, and a dashboard view, which cannot be removed from the project. All other items are created through workflows and can be removed.
Knowledge graph view
The knowledge graph view Knowledge graph is one of the default views in a Knowledge Studio project. The knowledge graph view allows you to explore the entities and relationships defined in the knowledge graph.
Learn more about exploring data in the knowledge graph view
Query view
The query view Query view is one of the default views in a Knowledge Studio and allows you to query the knowledge graph to find a subset of the entities and relationships it contains and identify how different entities are connected.
Learn more about querying a knowledge graph
Dashboard view
The dashboard view Dashboard view is one of the default views in a Knowledge Studio project that you can configure to synthesize key information about your project or analysis.
Learn more about configuring the dashboard
Content types
A Knowledge Studio project can have two content types:
  • Portal content—Content items stored on your organization's portal. This can include items you own, items shared with you by others, or public items available to your organization. Portal content is accessible from any project, as long as you have the right permissions.
  • Project content—Content items stored within your current project. These items are specific to the project you’re working on and can only be accessed within the project.
Each content type can be a different content item, such as maps, link charts, and data cards. Each content item opens in a view based on its type. Content items open in new tabs. The number of content items you can have open depends on the number of maps and link charts in each item.
Maps
You can create maps Map in a Knowledge Studio project to visualize the spatial entities in a knowledge graph. A map can be a portal content item or a project content item.
Learn more about adding a knowledge graph to a map
Link charts
You can create link charts Link chart in a Knowledge Studio project to visualize, analyze, and dynamically explore a knowledge graph. A link chart can be a portal content item or a project content item.
Learn more about adding a knowledge graph to a link chart
Data cards
You can create data cards Data card in a Knowledge Studio project to capture a snapshot of a single entity or relationship in the knowledge graph. A Data card can only be a project content item.
Learn more about creating a data card
Create a project
You can create a Knowledge Studio project from the Knowledge Studio landing page or by opening a knowledge graph item from your portal in Knowledge Studio.
Create a project from the landing page
From the Knowledge Studio landing page, you can browse, search, filter, and sort portal content to find the knowledge graph you want to work with and add it to a project. A new project is created, allowing you to analyze the knowledge graph's content.
  1. Click Create New Project.
    The Create New Project wizard appears.
  2. Optionally, provide a title for the project in the Project Title text box.
    The project is untitled by default.
  3. Use the Filter box and the My Contents drop-down menu to browse to or search for the knowledge graph you want to investigate, choose the knowledge graph, and click OK.
Create a project from a knowledge graph item
You can also create a Knowledge Studio project from a knowledge graph item in your portal.
  1. Open the item details page of the knowledge graph item.
  2. Click Open in Knowledge Studio.
A new Knowledge Studio project opens and lists the content items of the project. The project starts with the knowledge graph view and dashboard view. You can explore the knowledge graph further in the knowledge graph view.
New Knowledge Studio projects are not automatically saved.
Open an existing project
You can open an existing Knowledge Studio project from the Knowledge Studio landing page or by clicking the Knowledge Studio project item Knowledge Studio in your portal.
The Knowledge Studio landing page lists all projects that you can access in your portal.
  1. Browse to or search for the Knowledge Studio project you want to open.
  2. Click the project title to open it.
Rename a project
By default, a Knowledge Studio project has the same name as the knowledge graph it references. You can rename a project at any time.
  1. Click Edit Project Title Edit Project Title next to the project title on the title bar.
  2. Provide a new name for the project and press Enter.
  3. Click Save Save in the main menu to save the project.
Save a project
A Knowledge Studio project must be saved to retain changes to the project. If you refresh your browser without saving the project, all content items and views will be reset to the last project state you saved.
To save a Knowledge Studio project:
  1. Click Save Save in the main menu.
  2. Click Save in the drop-down menu.
  3. Optionally, Click Save As in the drop-down menu to save your work as a new project in your portal.
    The Save As opens.
    1. By default, the current name of the project is used for the Title. Optionally, type a new title.
    2. Select an existing portal folder for the project.
    3. Type a new tag and press Enter or click existing tags to add them to the project.
    4. Provide a summary for the project.
    5. Click Save.
The project and all changes are saved to your portal.
