Add a knowledge graph to a link chart
Create a link chart to visualize, analyze, and explore a knowledge graph's content. You can create a blank link chart in the Project Contents pane or you can start from any of the views in which you work with a knowledge graph: maps, the knowledge graph view, data cards, global search, query results, selection manager, and other link charts. You can select entities and relationships in the active view and add them to a new link chart.
When a link chart is created and opened, any entities you selected in the knowledge graph view, for example, are added. When you select and add a relationship, the relationship is added along with its origin and destination entities, even when those entities were not selected in the knowledge graph view. When you add entities and relationships to a link chart, a link chart layer is created in the Link Chart Contents pane. The entities and relationships added to the new link chart are arranged using the force directed layout by default; this becomes the current layout for the new link chart. You can change how records are arranged by applying a different layout option on the context toolbar.
Learn more about arranging records in a link chart
You can also add entities and relationships to an existing link chart from any of the places in which you work with a knowledge graph's content: maps, knowledge graph view, data cards, global search, query results, selection manager, and other link charts.
Regardless of the method you use to add content to a link chart, the layout currently in use for visualizing the link chart's content is automatically reapplied to the entire link chart.
Open a sublayer's attribute table to see the properties of the entities or relationships of that type.
You can also import link charts from a portal as long as the link chart uses the same knowledge graph as your project.
Knowledge Studio allows a maximum of 13 maps and link charts in open content items. If you have reached the limit, you need to close a tab before you can open the link chart. If you created a link chart, the link chart is created but not opened. Close a tab at the bottom of the view and click the new link chart in the Project Contents pane to open it.
Create a blank link chart
After you create a blank link chart, use any of the other methods listed to add data to the link chart.
  1. In the Project Contents pane, click Manage Content.
  2. Click the appropriate option to create a blank link chart in your project.
    • Click Link Chart to create a blank link default link chart.
    • Click Link Chart from Template to create a blank link chart using an existing link chart as a template.
      The content for a new link chart is typically arranged using the force directed layout, and default symbols are used to visualize entities and relationships. However, if you have imported a link chart that contains custom symbology, labels, pop-ups and so on, you can use it as a template. The new link chart layer will use the same custom layer definition as the existing link chart to visualize entities and relationships.
A link chart is created in the Project Contents pane.
Add content from the knowledge graph view
You can add a single record, an entire entity type, or specific instances of an entity or relationship type to a link chart from the knowledge graph view. When you add content to a link chart, a link chart layer representing the entire knowledge graph is created and added to the link chart but only the selected records are included in the layer. New link charts appear in the Project Contents pane.
Add a single entity or relationship
A record displayed in the details pane can be added to a link chart.
  1. On the context toolbar in the knowledge graph view, click Add To .
  2. Click the appropriate option to add a link chart layer to the link chart.
    • Under Add to new, click Link Chart to create a link chart in the project.
    • Under Add to existing, click the name of an existing link chart.
    • Click Link Chart from template under Add to new and select the link chart to use as the template. Click Add.
      You can use an existing link chart as a template even if it is not an open view.
Add multiple entities or relationships
Multiple entities of an entity or relationship type can be added to a link chart from the knowledge graph view.
  1. Check the check boxes to select entities or relationships from the record list.
  2. In the record list, click Add To .
  3. Click the appropriate option to add a link chart layer to the link chart.
Add an entire entity or relationship type
All instances of an entity or relationship type can be added to a link chart.
  1. Hover over an entity or relationship type in the Knowledge Graph Contents pane and click Options
Add an entire knowledge graph
All entities and relationships in the knowledge graph can be added to a link chart.
  1. In the Knowledge Graph Contents pane, click Add To next to the knowledge graph title.
The link chart opens in a tab and becomes the active view. The entities and relationships selected in the knowledge graph view are added and arranged using the appropriate link chart layout. The force directed layout is applied to the records in new link charts by default and default symbology is used. New link charts appear in the Project Contents pane.
Add content from the selection manager
You can add the records from the tool in a map view or link chart view to another link chart.
  1. Click Add To at the bottom of the Selection Manager pane.
Add content from an existing link chart
After creating a link chart from a project's knowledge graph, you can add selected content from the existing link chart to another link chart.
  1. Select the entities and relationships in the link chart that you want to add to the other link chart.
    • Use the interactive selection tools in the canvas toolbar to select entities and relationships on the link chart.
    • Press the Ctrl key while clicking the entities and relationships to add.
    • Click Select All on the canvas toolbar.
    • Select records in the link chart sublayer record table.
    • Press the Ctrl key while clicking the entities and relationships to deselect them.
    • Use the Selection Manager to deselect records.
    • Click anywhere on the link chart to deselect all entities and relationships.
  2. On the link chart context toolbar, click Add To .
Add content from a map
After creating a map from an project's knowledge graph, you can add selected content from the existing link chart to another link chart.
  1. Select the entities and relationships in the existing link chart that you want to add to the other link chart.
    • Press the Ctrl key while clicking the entities on the map.
    • Use the interactive selection tools in the canvas toolbar to select entities.
    • Select records in the entity or relationship type sublayer record table.
    • Press the Ctrl key while clicking selected entities on the map to deselect them.
    • Click anywhere on the map to deselect all entities and relationships.
Add content from a global search
Entities and relationships returned in global search results can be added to new or existing link charts.
  1. Select records by checking the check box next to each record.
  2. Click Add To at the top of the search results pane.
Add content from the query view
Entities and relationships returned from a query can be added to a new or existing link chart.
  1. Select records in the query results table.
  2. On the query context toolbar, click Add To .
Turn the visibility of link chart layers and sublayers on or off
You can show or hide a link chart layer and entity type and relation type sublayers in a link chart.
  1. Click Options Options next to the layer in the contents pane.
  2. Click Toggle visibility Visibility to show or hide the knowledge graph layer or its sublayers.
Rename a link chart layer or sublayers
A link chart layer and its sublayers can be renamed in the link chart view. Changing the name only changes the display name of the layer in the Link Chart Contents pane of the current link chart. It does not change the layer's name across other link charts in the project, or the name of the entity or relationship type the layer represents.
  1. Click Options next to the layer in the contents pane.
  2. Click Rename .
    The rename dialog box appears.
  3. Provide the new layer name and click OK.
Remove knowledge graph records from a link chart
Entities and relationships can be removed from a link chart. Removed records remain in other maps, link charts, and data cards in the project.
  1. Select the entities and relationships to remove from the link chart.
  2. On the link chart context toolbar, click Remove .
View the legend
Each entity type and relationship type in the link chart has default symbology applied. Use the legend to see the symbology for each sublayer.
On the canvas toolbar, click Toggle Legend Legend.
Change the basemap
Link charts use basemaps in a geographic layout. You can change the basemap to better visualize your data.
  1. On the context toolbar, click Change Basemap .
  2. Choose the basemap to use for the geographic layout.
