Register Amazon Web Services resources
You can register Amazon Relational Database Service (RDS) resources to collect system health and performance metrics.
Prerequisites for monitoring
The following prerequisites are necessary for monitoring RDS resources:
Caution:
Amazon charges a fee for certain CloudWatch features. Refer to CloudWatch Pricing for more information.
Register AWS for monitoring
You must be assigned the Administrator or Manager role to register components.
To register AWS, complete the following steps:
  1. Access ArcGIS Monitor if necessary.
    The Home page appears.
  2. Click Monitoring.
    The Monitoring page appears with registered components listed alphabetically by name.
  3. Click Register component.
    The Register component wizard appears.
    If you don't have sufficient privileges, Register component is not available.
  4. Choose a Monitor Agent machine that has access to AWS, and click Next.
    The Component type page appears.
  5. Under Cloud, choose Amazon Web Services, and click Next.
    The Component details page appears.
  6. Provide a name for the component in the Component name text box.
  7. Optionally, provide a description for the component in the Description text box.
  8. Optionally, click Apply Labels and choose the labels that you want to apply to the component.
    Tip:
    Provide the name of a label in the Enter label name text box to search for a specific label. If the label doesn't exist, click Create new label to add the label and apply it to the component.
  9. Click Next.
    The Connection page appears.
  10. Provide the following IAM authentication information in the Connection section:
  11. Click Register component.
    The component is added to the list of monitored components on the Monitoring page.
Once AWS RDS resources have been registered for monitoring, you can configure alert rules and add them to collections.
Individual databases hosted in RDS must be registered separately as database components; their metrics can't be acquired through CloudWatch.
Observers
The following table describes the observers that are responsible for collecting attribute and metric data:
Observer name
Inventory - Cloud AWS
This observer scans for changes and manages attribute data across the AWS account.
The default interval for this observer is 5 minutes; however, you can configure it to run at longer intervals since changes to AWS are typically infrequent.
Metrics - Cloud AWS
This observer collects metric data for monitored resources across the AWS account.
The default interval for this observer is 5 minutes to align with the CloudWatch basic monitoring interval. You can configure it to run at shorter intervals if your organization subscribes to CloudWatch detailed monitoring.
Collected attributes
The following table lists the attributes that are collected for RDS resources:
Attribute name
Data type
Class
The resource's instance type.
String
CPU cores logical
The CPU's total number of logical cores.
Integer
CPU cores physical
The CPU's total number of physical cores.
Integer
CPU name
The CPU name and model information.
String
CPU speed
The speed of the CPU.
Float
Location
The AWS availability zone.
String
Memory total
The resource's total amount of memory (RAM).
Float
Network speed
The speed of the network.
The network speed is displayed as 1000 Mbps.
Integer
System state
The status of the resource (available, running, or stopped).
String
Storage total
The size of the volume.
Float
Version
The version of the underlying database.
String
Collected metrics
The subsections below describe the metrics that are collected for AWS and tagged RDS resources.
AWS metrics
The following table lists the metrics that are collected for AWS:
Metric name
Data type
Unit
Connectivity
The agent's ability to successfully connect to the component.
Float
Percent
CPU utilized
The average proportion of CPU resources in use across all monitored AWS components.
Values approaching 100 percent may indicate that more resources are needed to handle the workload.
Float
Percent
Memory Available
The cumulative amount of available physical memory across all monitored AWS components.
Float
Gigabytes
Memory Used
The cumulative amount of memory in use across all monitored AWS components.
Float
Gigabytes
Memory Utilized
The average proportion of memory in use across all monitored AWS components.
Float
Percent
Network Incoming
The cumulative rate of network data received across all monitored AWS components.
Float
Megabits/second
Network Incoming Utilized
The average proportion of incoming network bandwidth in use across all monitored AWS components.
Float
Percent
Network Outgoing
The cumulative rate of network data sent across all monitored AWS components.
Float
Megabits/second
Network Outgoing Utilized
The average proportion of outgoing network bandwidth in use across all monitored AWS components.
Float
Percent
Storage Capacity Available
The cumulative amount of available storage space across all monitored AWS components.
Float
Gigabytes
Storage Capacity Used
The cumulative amount of storage space in use across all monitored AWS components.
Float
Gigabytes
Storage Capacity Utilized
The average proportion of storage capacity in use across all monitored AWS components.
Float
Percent
Storage Read Rate
The cumulative speed at which data is read from the disk across all monitored AWS components.
Float
Gigabytes/second
Storage Write Rate
The cumulative speed at which data is written to the disk across all monitored AWS components.
Float
Gigabytes/second
RDS metrics
The following table lists the metrics that are collected for RDS resources:
Metric name
Data type
Unit
CPU utilized
The proportion of CPU resources in use.
Float
Percent
Memory Available
The total amount of available physical memory.
Float
Gigabytes
Memory Used
The amount of memory in use.
Float
Gigabytes
Memory Utilized
The proportion of memory in use.
Float
Percent
Network Incoming
The rate of network data received.
Float
Megabits/second
The proportion of incoming network bandwidth in use.
Float
Percent
Network Outgoing
The rate of network data sent.
Float
Megabits/second
The proportion of outgoing network bandwidth in use.
Float
Percent
The amount of available storage space.
Float
Gigabytes
The amount of storage space in use.
Float
Gigabytes
The proportion of storage capacity in use.
Float
Percent
Storage Read Rate
The speed at which data is read from the disk.
Float
Gigabytes/second
Storage Write Rate
The speed at which data is written to the disk.
Float
Gigabytes/second
Default alert rules
The subsections below describe the default alert rules that are configured for the AWS site and its underlying services.
AWS alert rules
The following table lists the default alert rules that are configured for AWS:
Metric name
Aggregation
Operator
Info threshold
Warning threshold
Critical threshold
Samples
Connectivity
Average
Is less than
100
CPU Utilized
Average
Is greater than
75
90
Memory Utilized
Average
Is greater than
75
90
Average
Is greater than
75
90
The default alert rules in the table above are the rules that are configured for components when Monitor is first deployed. If your Monitor administrator has configured default alert rules for the Monitor deployment, the values for the rules above may vary.
RDS alert rules
The following table lists the default alert rules that are configured for RDS resources:
Metric name
Aggregation
Operator
Info threshold
Warning threshold
Critical threshold
Samples
CPU Utilized
Average
Is greater than
75
90
Memory Utilized
Average
Is greater than
75
90
Average
Is greater than
75
90
Component relationships
No relationships are formed between AWS and RDS resources in ArcGIS Monitor.
