Register ArcGIS Data Store
You can register ArcGIS Data Store relational data stores to collect metrics and attribute information.
Prerequisites for monitoring
The following prerequisites apply to monitoring a data store:
  • ArcGIS Monitor Agent must be installed on the data store machine and must be registered with ArcGIS Monitor Server.
    When you monitor high-availability deployments, install Monitor Agent on both relational data store machines in the deployment. This ensures continuous monitoring in the event of a machine failure and provides host metrics for each machine in the deployment.
  • Set the data store --enablessl option to true.
  • Configure Data Store to start with the operating system using systemd.
  • The Data Store versions listed below are supported for monitoring. The specific versions listed are the minimum certified versions. Newer minor versions are supported but are not certified unless otherwise stated.
    • ArcGIS Data Store 12.1
    • ArcGIS Data Store 12.0
    • ArcGIS Data Store 11.5
    • ArcGIS Data Store 11.3
    • ArcGIS Data Store 11.1
Obtain the Database Admin User credentials
The Database Admin User credentials are required to register a relational data store.
To obtain the credentials, complete the following steps:
  1. Sign in to the data store host machine as an administrator.
    The account must be a member of the Windows Administrator group.
  2. Open a command prompt window with Administrative privileges.
    You must open the command prompt with the Run as Administrator option to use the Data Store utilities.
  3. Start a terminal session.
  4. Run the command below and record the Database Admin User credentials.
    <ArcGIS Data Store installation location>\DataStore\tools\listadminusers.bat
    ./<ArcGIS Data Store installation location>/datastore/tools/listadminusers.sh
    The following is an example:
    C:\Program Files\ArcGIS\DataStore\tools\listadminusers.bat
    ./arcgis/arcgis/datastore/tools/listadminusers.sh
Register Data Store for monitoring
You must be assigned the Administrator or Manager role to register components.
To register a Data Store component, complete the following steps:
  1. Access ArcGIS Monitor if necessary.
    The Home page appears.
  2. Click Monitoring.
    The Monitoring page appears with registered components listed alphabetically by name.
  3. Click Register component.
    The Register component wizard appears.
    If you don't have sufficient privileges, Register component is not available.
  4. Choose the Monitor Agent machine where the component is installed, and click Next.
    The Component type page appears.
  5. Under ArcGIS, choose ArcGIS Data Store, and click Next.
    The Component details page appears.
  6. Provide a name for the component in the Component name text box.
  7. Optionally, provide a description for the component in the Description text box.
  8. Optionally, click Apply Labels and choose the labels that you want to apply to the component.
    Tip:
    Provide the name of a label in the Enter label name text box to search for a specific label. If the label doesn't exist, click Create new label to add the label and apply it to the component.
  9. Click Next.
    The Connection page appears.
  10. Provide the Database Admin User credentials in the Username and Password text boxes.
  11. Click Register component.
    The component is added to the list of monitored components on the Monitoring page.
Once a component is registered, you can configure alert rules and add the component to collections.
Other component types, such as the enterprise GIS implementation's underlying hardware infrastructure and databases, must be registered individually to enable monitoring.
Observers
The following table describes the observers that collect data store attribute and metric data:
Observer name
Inventory - ArcGIS Data Store
This observer scans for changes and manages attribute data and component relationships across a data store and its underlying datasets.
The default interval for this observer is 15 minutes; however, you can configure it to run at longer intervals since changes to the site configuration are typically infrequent.
Metrics - ArcGIS Data Store
This observer collects metric data across a data store and its underlying datasets.
The default interval for this observer is 5 minutes; however, you can configure it to run at shorter intervals to retrieve data more frequently.
Collected attributes
The subsections below describe the attributes that are collected for a data store and its underlying datasets.
Data store
The following table lists the attributes that are collected for a data store:
Attribute name
Data type
Connections max
The maximum number of connections that can be open at one time
Integer
Last backup at
The last time the data store was backed up
Datetime
Memory total
The total amount of memory (RAM) allocated to Data Store
Integer
Started at
The date and time Data Store was last started
Datetime
System mode
Specifies the mode of the system:
  • read
  • read/write
String
System state
Specifies the state of the system as it is configured in Data Store:
  • started
  • stopped
String
Version
The software version of Data Store
String
Data store datasets
The following table lists the attributes that are collected for datasets in a data store:
Attribute name
Data type
Geometry type
Specifies the geometry type of the dataset:
  • Line
  • Point
  • Polygon
  • - (None)
String
Is archived
Specifies whether the dataset is archived:
  • No
  • Yes
String
Last modified at
The data and time the dataset was last modified
Datetime
Versioned type
Specifies the dataset's versioned type:
  • Branched
  • Traditional
  • - (None)
String
Collected metrics
The subsections below describe the metrics that are collected for Data Store and its underlying datasets.
Data store metrics
The following table lists the metrics that are collected for a data store:
Metric name
Data type
Unit
Cache Hit
The percentage of requests served from the cache, as opposed to requests served from disk.
Float
Percentage
Connectivity
The agent's ability to successfully connect to the component.
Float
Percent
Database Connections
The total number of active connections.
Float
Percent
Database Connections Utilized
The proportion of allocated database connections in use.
Values approaching 100 may indicate that the current allocation is insufficient.
Float
Percent
Datasets
The total number of datasets.
Float
Total
Open Cursors
The number of open cursors in the database.
Float
Total
Rows Total
The total number of rows in all tables in the database.
Float
Total
Storage Used
The total amount of storage used by all tables in the database.
Float
Total
Data store dataset metrics
The following table lists the metrics that are collected for datasets in a data store:
Metric name
Data type
Unit
Rows Total
The total number of rows in the dataset
Float
Total
Storage Used
The total amount of storage used by the dataset
Float
Total
Default alert rules
The following table lists the default alert rules that are configured for a data store:
Metric name
Aggregation
Operator
Info threshold
Warning threshold
Critical threshold
Samples
Connectivity
Average
Is less than
100
Cache Hit
Average
Is less than
90
The default alert rules in the table above are the rules that are configured for components when Monitor is first deployed. If your Monitor administrator configured default alert rules for the Monitor deployment, the values for the rules above may vary.
Component relationships
The subsections below describe the relationships that are formed with registered Data Store components.
Relational data store datasets
The Data Store inventory observer detects the relational data store datasets created by Data Store, and individual relationships are formed between the Data Store component and each of its datasets. When registered with a monitored ArcGIS Server site, the ArcGIS Server inventory observer discovers and manages relationships between its services and relational data store datasets.
If the Data Store component is unregistered in Monitor, its datasets are also unregistered.
Host
A host's inventory observer detects instances of Data Store running on the host machine, and a relationship is formed between the host component and the registered Data Store component.
For highly available Data Store deployments with multiple hosts, register each host machine and each Data Store instance so Monitor can form relationships between individual Data Store components and participating host machines.
ArcGIS Server
When Data Store is registered with a monitored ArcGIS Server site, the ArcGIS Server inventory observer discovers and manages relationships between the ArcGIS Server site and the Data Store component.
If the Data Store component is unregistered in Monitor, the relationship between the ArcGIS Server site and ArcGIS Data Store component is removed.
