Register ArcGIS Server
You can register stand-alone and federated ArcGIS Server sites to collect system health and performance metrics.
When ArcGIS Monitor Agent cannot be installed on the ArcGIS Server site machines, you can register the site using the ArcGIS Server (Remote) component. This allows you to collect service health and performance metrics for ArcGIS Server services.
Prerequisites for monitoring
The following prerequisites apply to monitoring ArcGIS Server sites:
  • ArcGIS Monitor Agent must be installed on at least one ArcGIS Server machine and must be registered with ArcGIS Monitor Server.
    When monitoring a multimachine site, install ArcGIS Monitor Agent on all machines in the site. This ensures continuous monitoring of the site in the event of a machine failure and provides host metrics for each machine in the site.
  • The following versions of ArcGIS Server are supported for monitoring. The specific versions listed are the minimum certified versions. Newer minor versions are supported but are not certified unless otherwise stated.
    • ArcGIS Server 12.1
    • ArcGIS Server 12.0
    • ArcGIS Server 11.5
    • ArcGIS Server 11.3
    • ArcGIS Server 11.1
  • To register an ArcGIS Server site for monitoring, use the ArcGIS Server primary site administrator account or an equivalent ArcGIS Server account assigned the Administrator role type.
    For a federated ArcGIS Server site, the ArcGIS Server primary site administrator user account is required.
  • Configure ArcGIS Server HTTP protocol setting to allow communication over HTTPS.
  • Authentication requires ArcGIS Server token-based security. Other forms of authentication such as Integrated Windows Authentication (IWA) and Security Assertion Markup Language (SAML) are not supported.
  • When you register an ArcGIS Server site with Monitor, Monitor makes the following changes to ArcGIS Server settings:
    • The monitorSystemId field is added to the Server Properties object and contains a unique identifier for the ArcGIS Server site.
    • Monitor manages Usage Report settings. Monitor sets the samplingInterval parameter to 1 minute to align with the Metrics - ArcGIS Server observer's interval and sets the maxHistory parameter to 1 day to prevent unnecessary history from accumulating.
    • A Monitor-managed usage report is added to support the collection of metrics. The usage report name is prefixed with agm- followed by a unique Monitor deployment identifier.
Register an ArcGIS Server component for monitoring
Use an account assigned the Administrator or Manager role to register components.
To register an ArcGIS Server component, complete the following steps:
  1. Access ArcGIS Monitor if necessary.
    The Home page appears.
  2. Click Monitoring.
    The Monitoring page appears with registered components listed alphabetically by name.
  3. Click Register component.
    The Register component wizard appears.
    If you don't have sufficient privileges, Register component is not available.
  4. Choose the Monitor Agent machine where the component is installed, and click Next.
    The Component type page appears.
  5. Under ArcGIS, choose ArcGIS Server, and click Next.
    The Component details page appears.
  6. Provide a name for the component in the Component name text box.
  7. Optionally, provide a description for the component in the Description text box.
  8. Optionally, click Apply Labels and choose the labels that you want to apply to the component.
    Tip:
    Provide the name of a label in the Enter label name text box to search for a specific label. If the label doesn't exist, click Create new label to add the label and apply it to the component.
  9. Click Next.
    The Connection page appears.
  10. Provide the credentials of an ArcGIS Server site administrator in the Username and Password text boxes as follows:
    • For federated ArcGIS Server sites, you must provide credentials for the ArcGIS Server primary site administrator account to register the site.
    • For unfederated ArcGIS Server sites, you must provide credentials for an ArcGIS Server user account with the Administrator role to register the site.
  11. Click Register component.
    The component is added to the list of monitored components on the Monitoring page.
Once a component is registered, you can configure alert rules and add the component to collections.
Other component types, such as the enterprise GIS implementation's underlying hardware infrastructure and databases, must be registered individually to enable monitoring.
Observers
The following table describes the observers that collect ArcGIS Server site attribute and metric data:
Observer name
Check - Service
This optional, user-configured observer sends a request to an ArcGIS Server service and uses a regular expression pattern to validate its JSON response.
Inventory - ArcGIS Server
This observer scans for changes and manages attribute data and component relationships across the ArcGIS Server site and its underlying services.
The default interval for this observer is 5 minutes; however, you can configure it to run at longer intervals since changes to the site configuration are typically infrequent.
Logs - ArcGIS Server
This observer collects log entries for the ArcGIS Server site for display in Monitor.
The default interval for this observer is 1 minute to retrieve data frequently. Do not run this observer at longer intervals.
This observer collects metric data across the ArcGIS Server site and its underlying services.
The default interval for this observer is 5 minutes; however, you can configure it to run at shorter intervals to retrieve data more frequently.
Sessions - ArcGIS Server
After ArcGIS Server is registered with Monitor, restart ArcGIS Server so this observer can scan logs for application usage.
The default interval for this observer is 1 minute to retrieve data frequently. It is not recommended to run this observer at longer intervals.
Collected attributes
The subsections below describe the attributes that are collected for the ArcGIS Server site and its underlying services.
ArcGIS Server
The following table lists the attributes that are collected for the ArcGIS Server site:
Attribute name
Data type
License expiration
The date and time the ArcGIS Server site's license expires
Datetime
Machines
The list of machines or hosts that participate in the ArcGIS Server site
Array
Roles
The list of ArcGIS Server roles assigned to the ArcGIS Server site
Array
Shared instances max
The maximum number of shared service instances
Integer
Shared instances min
The minimum number of shared service instances
Integer
Started at
The date and time the ArcGIS Server site was last started
Datetime
Version
The software version of the ArcGIS Server site
String
The following table lists the attributes that are collected for the ArcGIS Server site's underlying services:
Attribute name
Data type
Cached service
Specifies whether data is returned dynamically or returned from a cache when queried.
Boolean
Configured state
Specifies the state of the service as it is configured in ArcGIS Server (started or stopped).
String
Idle time max
The maximum number of seconds a service instance is allowed to persist before it shuts down.
Integer
Instance type
Specifies the infrastructure of the underlying service provider (hosted, shared, dedicated, or custom).
String
Instances max
The maximum number of service instances configured across the ArcGIS Server site.
For hosted and custom instances, this value is always displayed as zero. For shared instances, this value is the maximum number of shared instances configured for the site. For dedicated instances, this is the maximum number of instances configured for the service.
Integer
Instances min
The minimum number of service instances configured across the ArcGIS Server site.
For hosted and custom instances, this value is always displayed as zero. For shared instances, this value is the minimum number of shared instances configured for the site. For dedicated instances, this is the minimum number of instances configured for the service.
Integer
Is remote
Specifies whether the service is remote.
Boolean
Wait time max
The maximum number of seconds a client waits to connect to the service before it times out.
Integer
Collected metrics
The subsections below describe the metrics that are collected for the ArcGIS Server site and its underlying services.
ArcGIS Server metrics
The following table lists the metrics that are collected for the ArcGIS Server site:
Metric name
Data type
Unit
Connectivity
The agent's ability to successfully connect to the component.
Float
Percent
Instances Saturation Percent
The percentage of maximum configured service instances in use.
This metric is calculated by dividing the service's busy time with its maximum potential busy time, and multiplying this value by 100.
The service busy time is calculated by multiplying the service's average response time (RT) by the number of requests (RR) over the interval.
The maximum potential busy time is calculated by multiplying the service's maximum configured instances (IC) by the interval (I).
The following is an example:
(RT*RR)/(IC*I)*100
(0.1*1000)/(2*60)*100
83% of maximum configured service instances
Values approaching 100 percent may indicate that more instances are needed to handle incoming service requests.
Float
Percent
Instances Used
The total number of service instances in use.
This metric is calculated by dividing the instances saturation percent metric value (ISP) by 100, and multiplying this value by the maximum configured instances (IC).
The following is an example.
(ISP/100)*IC
(83/100)*2
1.66 instances used
Float
Total
Request Rate
The average request rate of all ArcGIS Server site services.
Float
Requests/second
Request Response Time Avg
The average response time of all ArcGIS Server site services.
Float
Seconds
Request Response Time Max
The maximum response time of all ArcGIS Server site services.
Float
Seconds
Request Wait Time Average
The average time that all requests waited for an available ArcSOC instance over a period of time (total wait time for all requests divided by the number of requests).
Float
Seconds
Request Wait Time Max
The maximum time that a service request waited for an available ArcSOC instance over the specified period.
Float
Seconds
Request Wait Time Min
The minimum time that a service request waited for an available ArcSOC instance over the specified period.
Float
Seconds
Requests Error Percent
The percentage of failed and timed-out requests of all ArcGIS Server site services.
Float
Percent
Requests Failed
The total number of failed requests of all ArcGIS Server site services.
Float
Total
Requests Received
The total number of received requests of all ArcGIS Server site services.
Float
Total
Requests Timed Out
The total number of timed-out requests of all ArcGIS Server site services.
Float
Total
Services
The total number of ArcGIS Server services.
Float
Total
Site Machines Availability
The total percentage of machines that are available in the ArcGIS Server site.
Values under 100 percent indicate that some of the machines in the site are unavailable for processing and may require further investigation.
Float
Percent
ArcGIS Server services metrics
Monitor collects information about the following ArcGIS Server service types:
  • Feature
  • Geocode
  • Geodata
  • Image
  • Map
  • Network Analyst
  • Geoprocessing
The following table lists the metrics that are collected for the ArcGIS Server site's underlying services:
Metric name
Data type
Unit
Float
Percent
Instances Used
Float
Total
Request Rate
The service's average request rate.
Float
Requests/second
The service's average response time.
Float
Seconds
The service's maximum response time.
Float
Seconds
The percentage of failed and timed-out service requests.
Float
Percent
Requests Failed
The total number of failed service requests.
Float
Total
Requests Received
The total number of received service requests.
Float
Total
Requests Timed Out
The total number of service requests that timed out.
Float
Total
CPU Utilized
The average percentage of CPU resources used by the service's ArcSOC processes across all machines in the site.
This metric only applies to services with a dedicated instance type. Services with a shared or hosted instance type are not included.
Higher values may indicate that more CPU resources are needed to handle the current workload. This metric can help determine whether to adjust the number of configured service instances to better balance workload with available resources.
Float
Percent
CPU Utilized - <machine_name>
The percentage of CPU resources used by the service's ArcSOC processes on the machine.
For sites with multiple machines, a separate metric is reported for each machine. The metric name includes the machine name (for example, CPU Utilized - SERVER1.DOMAIN.COM).
Float
Percent
Memory Utilized
The average percentage of memory used by the service's ArcSOC processes across all machines in the site.
Higher values may indicate that more memory resources are needed to handle the current workload. This metric can help determine whether to adjust the number of configured service instances to better balance workload with available resources.
Float
Percent
Memory Utilized - <machine_name>
The percentage of memory used by the service's ArcSOC processes on the machine.
For sites with multiple machines, a separate metric is reported for each machine. The metric name includes the machine name (for example, Memory Utilized - SERVER1.DOMAIN.COM).
Float
Percent
Optional metrics for ArcGIS Server services
The following table lists the optional metrics that can be collected by configuring the Check - Service observer for ArcGIS Server services:
Metric name
Data type
Unit
Check Response Code - <observer_name>
The request HTTP response code.
Float
Total
Check Response Matches - <observer_name>
The total number of matches returned by the regular expression defined in the observer.
If no regular expression is defined, a null value is returned.
Float
Total
Check Response Size - <observer_name>
The size of the response payload.
Float
Kilobytes
Check Response Time - <observer_name>
The response time of the check.
Float
Seconds
Enable optional metrics
To enable optional metrics for ArcGIS Server services, complete the following steps:
    The Monitoring page appears with registered components listed alphabetically by component name.
  3. Click the name of the ArcGIS Server service for which you want to enable optional metrics.
    The service's Overview page appears with its details and an overview of its metrics.
    Tip:
    You can type a keyword in the Search by component name or address text box to search for specific components and subcomponents.
  4. Click the Observers tab.
    The Observers page appears.
  5. Click Add observer.
    The Add observer dialog box appears.
  6. Choose Check - Service, and click Next.
    The Observer details page appears.
  7. Provide a name for the observer in the Observer name text box.
    The observer name is used to identify the observer, and all metrics associated with the observer are prefixed with the observer name. For example, if the observer name is Health Check, the name of its metrics would be <MetricName> - health_check.
  8. Optionally, provide a description for the observer in the Description text box.
  9. Click Next.
    The Configuration page appears.
  10. Click the Interval drop-down arrow, and choose an interval.
  11. Provide the resource and operation in the Request URL text box.
    The following is an example of the query operation for layer 0 of the Sample World Cities map service:
    /0/query
    The observer inherits the credentials of the associated ArcGIS Server component and automatically sets the response format to JSON.
  12. Click the Request method drop-down arrow, and choose the type of request that you want to send to the service.
  13. Optionally, provide key-value pairs for data that you want to be sent in the URL query string (GET) or request body (POST) under Request data.
    For example, to return the total number of features in layer 0 of the Sample World Cities map service, add the following key-value pairs:
    Key
    Value
    where
    1=1
    returnCountOnly
    true
    The f parameter is automatically set to json when the request is sent.
  14. Optionally, provide a regular expression pattern to validate the request's JSON response in the Response check text box.
    For example, to determine if there are 2,232 features in layer 0 of the Sample World Cities map service, add the following regular expression pattern:
    \b2232\b
    The ignoreCase, multiline, and global properties are used when validating the JSON response.
  15. Click Next.
    The Test page appears.
  16. Click Test to validate the configuration.
    The result of the test appears on the Test page.
  17. Click Add observer.
    The observer is added to the list of observers on the Observers page.
Optional metrics are collected and automatically appear in Monitor according to the observer's configured interval.
Default alert rules
The subsections below describe the default alert rules that are configured for the ArcGIS Server site and its underlying services.
ArcGIS Server alert rules
The following table lists the default alert rules that are configured for the ArcGIS Server site:
Metric name
Aggregation
Operator
Info threshold
Warning threshold
Critical threshold
Samples
Connectivity
Average
Is less than
100
Request Rate
Average
Is greater than or equal to
30
Average
Average
Average
30
Average
Is less than or equal to
99
The default alert rules in the table above are the rules that are configured for components when Monitor is first deployed. If your Monitor administrator configured default alert rules for the Monitor deployment, the values for the rules above may vary.
ArcGIS Server services alert rules
The following table lists the default alert rules that are configured for the ArcGIS Server site's underlying services:
Metric name
Aggregation
Operator
Info threshold
Warning threshold
Critical threshold
Samples
CPU utilized
Average
75
90
Memory utilized
Average
75
90
Instances saturation percent
Average
50
90
Request rate
Average
30
Request response time average
Average
Request response time max
Average
Requests error percent
Average
30
ArcGIS Server services optional metrics alert rules
The following table lists the default alert rule that is configured for optional ArcGIS Server service metrics:
Metric name
Aggregation
Operator
Info threshold
Warning threshold
Critical threshold
Samples
Average
300
400
500
The default alert rule in the table above is the rule that is configured for components when Monitor is first deployed. If your Monitor administrator configured default alert rules for the Monitor deployment, the values for the rule above may vary.
Component relationships
The subsections below describe relationships that are automatically formed with registered ArcGIS Server components.
The ArcGIS Server inventory observer detects ArcGIS Server services created in the ArcGIS Server site, and individual relationships are formed between the ArcGIS Server component and its services. When an ArcGIS Server site is registered with a monitored ArcGIS Data Store component, the ArcGIS Server inventory observer discovers and manages relationships between its services and relational data store datasets.
If ArcGIS Server is unregistered for monitoring, its services are also unregistered.
Host
A host's inventory observer detects instances of ArcGIS Server running on the host machine, and a relationship is formed between the host component and the registered ArcGIS Data Store component.
For highly available ArcGIS Server deployments with multiple hosts, each host machine and ArcGIS Server instance in the deployment must be registered for relationships to be formed between the individual ArcGIS Server components and participating host machines.
Portal for ArcGIS
The portal's inventory observer detects ArcGIS Server sites that are registered with the portal. If the detected ArcGIS Server site is registered for monitoring, a relationship is formed between the Portal for ArcGIS component and the ArcGIS Server component.
If ArcGIS Server is unregistered from the portal, the relationship is removed, but monitoring of the ArcGIS Server component continues.
ArcGIS Data Store
When Data Store is registered with a monitored ArcGIS Server site, the ArcGIS Server inventory observer discovers and forms relationships between the ArcGIS Server site and the registered ArcGIS Data Store component.
If Data Store is unregistered from ArcGIS Server, the relationship is removed, but monitoring of the Data Store component continues.
ArcGIS GeoEvent Server
When GeoEvent Server is registered with a monitored ArcGIS Server site, the ArcGIS Server inventory observer discovers and manages relationships between the ArcGIS Server site and the ArcGIS GeoEvent Server component.
If GeoEvent Server is unregistered from ArcGIS Server, the relationship is removed, but monitoring of the ArcGIS GeoEvent Server component continues.
Microsoft SQL Server
When SQL Server databases are registered with a monitored ArcGIS Server site, the ArcGIS Server inventory observer discovers and forms individual relationships between the ArcGIS Server site and the registered SQL Server database components.
If the SQL Server database is unregistered from ArcGIS Server, the relationship is removed, but monitoring of the SQL Server database component continues.
Oracle
When Oracle databases are registered with a monitored ArcGIS Server site, the ArcGIS Server inventory observer discovers and forms individual relationships between the ArcGIS Server site and the registered Oracle database components.
If the Oracle database is unregistered from ArcGIS Server, the relationship is removed, but monitoring of the Oracle database component continues.
PostgreSQL
When PostgreSQL databases are registered with a monitored ArcGIS Server site, the ArcGIS Server inventory observer discovers and forms individual relationships between the ArcGIS Server site and the registered PostgreSQL database components.
If the PostgreSQL database is unregistered from ArcGIS Server, the relationship is removed, but monitoring of the PostgreSQL database component continues.
