Register Oracle databases
You can register databases and geodatabases in Oracle to collect metrics and attribute information.
Prerequisites for monitoring
The following prerequisites apply to monitoring databases and geodatabases in Oracle:
  • Install ArcGIS Monitor Agent on a machine that has access to the Oracle machine and register it with ArcGIS Monitor Server.
    If the Oracle machine is accessible, install Monitor Agent on that machine to collect operating system metrics.
    The following Oracle versions are supported for monitoring. The specific versions listed are the minimum certified versions. Newer patch updates to these versions are supported but are not certified unless otherwise stated.
    • Oracle 26ai 23.26.1.0.0 (Linux only)
    • Oracle 19c (64 bit) 19.3.0.0
    The Monitor software includes client drivers.
  • If Monitor Agent is not installed on the Oracle machine, configure the firewall to allow communication between Oracle and the ArcGIS Monitor machine on port 1521.
    If Oracle runs on a different port, allow communication on that port instead.
  • Add the ST_Geometry type to the Oracle database to enable monitoring.
  • The Oracle user account that you use to register the database for monitoring must have the following read permissions to collect attribute and metric data:
    • SDE system tables (if applicable)
    • v$instance
    • v$session
    • v$sesstat
    • v$sga
    • v$statname
    • v$sysmetric_history
    • DUAL
  • Configure the Oracle user account to use password version 11G or later.
    Tip:
    To view password verifiers for DBA_USERS, run the following query: SELECT USERNAME, PASSWORD_VERSIONS FROM DBA_USERS;.
    Caution:
    Grant only read permissions to the Oracle user account to prevent custom database queries from altering the database.
Register databases for monitoring
You must have the Administrator or Manager role to register components.
To register databases and geodatabases in Oracle, complete the following steps:
  1. Access ArcGIS Monitor if necessary.
    The Home page appears.
  2. Click Monitoring.
    The Monitoring page appears with registered components listed alphabetically by name.
  3. Click Register component.
    The Register component wizard appears.
    If you don't have sufficient privileges, Register component is not available.
  4. Choose the Monitor Agent machine where the component is installed, and click Next.
    If you cannot install Monitor Agent on the machine, choose a Monitor Agent machine that has access to the database instead.
    The Component type page appears.
  5. Under Database, choose Oracle, and click Next.
    The Component details page appears.
  6. Provide a name for the component in the Component name text box.
  7. Optionally, provide a description for the component in the Description text box.
  8. Optionally, click Apply Labels and choose the labels that you want to apply to the component.
    Tip:
    Provide the name of a label in the Enter label name text box to search for a specific label. If the label doesn't exist, click Create new label to add the label and apply it to the component.
  9. Click Next.
    The Connection page appears.
  10. Provide the fully qualified domain name or IP address and port number of the database instance that you want to register in the Address text box.
    The default port number for Oracle is 1521.
  11. Provide the service name of the database that you want to register in the Service name text box.
  12. Provide the credentials for the database in the Username and Password text boxes.
  13. If the database requires encrypted connections, check the Require encryption check box.
  14. Click Register component.
    The component is added to the list of monitored components on the Monitoring page.
After you register a component, you can configure alert rules and add it to collections.
You must register other component types individually to enable monitoring, such as the enterprise GIS implementation's underlying hardware infrastructure and ArcGIS software.
Observers
The following table describes the observers that collect attribute and metric data:
Observer name
Database Query
This optional, user-configured observer runs an SQL query on the registered Oracle database and returns a single numeric value.
Inventory - Database Oracle
This observer scans for changes and manages attribute data and component relationships across the registered Oracle database. It also detects enterprise geodatabase schemas to enable related metrics.
The default interval for this observer is 10 minutes; however, you can configure it to run at longer intervals since changes to the database configuration are typically infrequent.
Metrics - Database Oracle
This observer collects metric data across the registered Oracle database. If the Inventory observer does not detect an enterprise geodatabase schema, Monitor does not collect geodatabase-related metrics.
The default interval for this observer is 1 minute; however, you can configure it to run at longer intervals since significant database variations are typically infrequent.
Collected attributes
The following subsections describe the attributes collected for registered databases and geodatabases in Oracle.
Database attributes
The following table lists the attributes that are collected for databases in Oracle:
Attribute name
Data type
Connections max
The maximum number of connections
Integer
Last backup at
The date and time the database was last backed up
Datetime
Memory total
The total amount of system global area (SGA) memory for the database instance
Float
Started at
The last start time of the database instance
Datetime
System mode
Specifies the state of the system as it is configured in Oracle:
  • Read
  • Read Write
String
UTC offset
The UTC time zone offset for the database instance
Integer
Version
The software version of the Oracle instance
String
Geodatabase attributes
The following table lists the attribute that is collected for geodatabases in Oracle:
Attribute name
Data type
Geodatabase version
The version of the enterprise geodatabase
String
Geodatabase dataset attributes
The following table lists the attributes that are collected for geodatabase datasets:
Attribute name
Data type
Geometry type
Specifies the geometry type of the dataset:
  • Line
  • Point
  • Polygon
  • - (None)
String
Is archived
Specifies whether the dataset is archived:
  • No
  • Yes
String
Versioned type
Specifies the dataset's versioned type:
  • Branched
  • Traditional
  • - (None)
String
Collected metrics
The following subsections describe the metrics collected for registered databases and geodatabases in Oracle.
Database metrics
The following table lists the metrics that are collected for databases in Oracle:
Metric name
Data type
Unit
Cache Hit
The percentage of requests served from the cache, as opposed to requests served from disk
Float
Percent
Connectivity
The agent's ability to successfully connect to the component
Float
Percent
Database Connections
The total number of database connections in use
Float
Total
Database Connections Utilized
The proportion of database connections in use
Float
Percent
Database Sessions
The number of open sessions in the database
Float
Total
Open Cursors
The number of open cursors in the database
Float
Total
Storage Used
The total amount of storage used
Float
Total
Geodatabase metrics
The following table lists the metrics that are collected for geodatabases in Oracle:
Metric name
Data type
Unit
Datasets
The total number of datasets
Float
Total
GDB Branch Version Conflicts
The total number of branch version conflicts in the geodatabase
Float
Total
GDB Branch Version Locks
The total number of locks on branch versions in the geodatabase
Float
Total
GDB Branch Versions
The total number of branch versions in the geodatabase
Float
Total
GDB Connections
The total number of active connections to the geodatabase
Float
Total
GDB Connections - editors
The total number of active editor connections to the geodatabase
Float
Total
GDB Connections - viewers
The total number of active viewer connections to the geodatabase
Float
Total
GDB Default Version Depth
The depth in the state tree of the default version
Float
Total
GDB Shared Locks
The total number of shared table locks in the geodatabase
Float
Total
GDB State Lineages
The total number of edits in the geodatabase for datasets that use traditional versioning
Float
Total
GDB Version States
The total number of states in the geodatabase for datasets that use traditional versioning
Float
Total
GDB Versions
The total number of versions in the geodatabase that use traditional versioning
Float
Total
Rows Total
The total number of rows
Float
Total
Storage Used
Float
Total
Geodatabase dataset metrics
The following table lists the metrics that are collected for geodatabase datasets in Oracle:
Metric name
Data type
Unit
Rows Total
Float
Total
Storage Used
Float
Total
To minimize performance impacts on monitored geodatabases, Monitor uses the database's statistics capability to collect dataset metrics. The accuracy of the metrics may diverge as statistics become obsolete and need to be recalculated.
Optional metrics
The following table lists the optional metrics that you can collect by configuring the Database Query observer:
Metric name
Data type
Unit
Database Query - <observer_name>
The response of the SQL query
Float
Total
Enable optional metrics
To enable optional metrics for Oracle databases and geodatabases, complete the following steps:
    The Monitoring page appears with registered components listed alphabetically by component name.
  3. Click the name of the Oracle database or geodatabase component for which you want to enable optional metrics.
    The database's Overview page appears with its details and an overview of its metrics.
    Tip:
    Type a keyword in the Search by component name or address text box to search for specific components and subcomponents.
  4. Click the Observers tab.
    The Observers page appears.
  5. Click Add observer.
    The Add observer dialog box appears.
  6. Choose Database Query, and click Next.
    The Observer details page appears.
  7. Provide a name for the observer in the Observer name text box.
    The observer name identifies the observer, and all metric names include the observer name as a prefix. For example, if the observer name is Health Check, the metric names are <MetricName> - health_check.
  8. Optionally, provide a description for the observer in the Description text box.
  9. Click Next.
    The Configuration page appears.
  10. Click the Interval drop-down arrow, and choose an interval.
  11. Provide an SQL query that returns a single numeric value in the Query text box.
    The following is an example query that returns the number of days since the database was last backed up:
    SELECT ROUND(SYSDATE - MAX(completion_time)) AS last_backup_days
    FROM v$backup_set
    WHERE backup_type IN ('I', 'D');
    The observer inherits the credentials of the associated Oracle database or geodatabase component.
  12. Click Test to validate the SQL query.
    The result of the test appears in the Results section.
  13. Click Add observer.
    The observer is added to the list of observers on the Observers page.
    The Add observer button is only available when the SQL query test result is successful.
Optional metrics are collected and automatically appear in Monitor according to the observer's configured interval.
Default alert rules
The following table lists the default alert rules for Oracle databases:
Metric name
Aggregation
Operator
Info threshold
Warning threshold
Critical threshold
Samples
Cache Hit
Average
Is less than
90
Connectivity
Average
Is less than
100
The default alert rules in the table above are configured for components when Monitor is first deployed. If your Monitor administrator configured default alert rules for the Monitor deployment, the values for the rules above may vary.
Component relationships
The following subsections describe the relationships formed with registered Oracle database components.
Geodatabase datasets
The inventory observer for Oracle databases detects only datasets in a geodatabase and forms individual relationships between the Oracle database component and its datasets. When registered with a monitored ArcGIS Server site, the ArcGIS Server inventory observer discovers and manages relationships between its services and the database's datasets.
If you unregister the Oracle component in Monitor, Monitor also unregisters the datasets in the component.
Host
A host's inventory observer detects instances of Oracle running on the host machine and forms a relationship between the host component and the registered Oracle database component.
Monitor cannot form host relationships for remotely monitored databases because the host is unavailable for monitoring.
ArcGIS Server
When you register an Oracle database with a monitored ArcGIS Server site, the ArcGIS Server inventory observer discovers and manages relationships between the ArcGIS Server site and the Oracle database component.
If you unregister the Oracle database component in Monitor, Monitor removes the relationship between the ArcGIS Server site and the Oracle database component.
