Generalization geoprocessing functions
Available with Spatial Analyst license.
The Generalization analysis geoprocessing functions are used to either clean up small erroneous data in the raster or generalize the data to get rid of unnecessary detail for a more general analysis.
There are several common sources for the erroneous data, such as the following:
  • Classified satellite imagery may contain many small areas of misclassified cells.
  • Images that are scanned paper maps may contain unnecessary lines or text.
  • Conversion issues from rasters in different formats, resolutions, or projections may exist.
The generalization geoprocessing functions help you identify such areas and automate the assignment of more reliable values to the cells that make up the areas.
They are divided into several general categories:
The following table lists the available geoprocessing functions and provides a brief description of each.
Geoprocessing Function
Aggregate
Generates a reduced-resolution version of a raster. Each output cell contains the Sum, Minimum, Maximum, Mean, or Median of the input cells that are encompassed by the extent of that cell.
Boundary Clean
Smooths the boundary between zones in a raster.
Expand
Expands specified zones of a raster by a specified number of cells.
Majority Filter
Replaces cells in a raster based on the majority of their contiguous neighboring cells.
Nibble
Replaces cells of a raster corresponding to a mask with the value of the nearest neighbor.
Region Group
For each cell in the output, the identity of the connected region to which that cell belongs is recorded. A unique number is assigned to each region.
Shrink
Shrinks the selected zones by a specified number of cells by replacing them with the value of the cell that is most frequent in its neighborhood.
Thin
Thins rasterized linear features by reducing the number of cells representing the width of the features.
Geoprocessing functions in the Generalization category
