Processing extent
Many geoprocessing tools allow you to specify a processing extent in which only the features or raster cells that intersect the extent will be processed. Setting the processing extent defines the geographic area of interest for every tool that is run.
The extent is a rectangle with minimum and maximum x (longitude) and y (latitude) coordinates. The coordinates that comprise this rectangle are left (minimum x), right (maximum x), top (maximum y), and bottom (minimum y).
A processing extent can be set as a tool parameter, tool environment, or project geoprocessing environment. Examples of tools that use a processing extent to define the area to create a feature or raster dataset include Create Random Points, Generate Tessellation, and Create Random Raster.
Set the extent
You can provide coordinates for the X and Y Extent section using the Top, Left, Right, and Bottom extent coordinate boxes.
You can also populate the extent coordinate boxes using the extent options. Extent options may include the following:
Current Display Extent
—The extent will be based on the active map or scene. This option is only available when there is an active map.Draw Extent
—The extent will be based on a rectangle drawn on the map or scene. This option will create a feature class in the project geodatabase and add a layer to the map. The feature class will have the same coordinate system as the map.Note:
This option is not available in the Environments dialog box. It is only available from a tool parameter with an extent data type or from the Environments tab on a tool dialog box.
When the Enable and disable editing from the Edit tab editing option is checked, you must enable editing on the Edit ribbon tab to draw the extent.
Extent of a Layer
—The extent will be based on an active map layer. Use the drop-down list to choose an available layer or use the Extent of data in all layers option to get the combined extent of all active map layers, excluding the basemap. This option is only available when there is an active map with layers.Each map layer has the following options:
All Features
—The extent of all features in the layer.Selected Features
—The extent of the selected features in the layer.Visible Features
—The extent of visible features in the layer.Note:
The extents from the Selected Features
and Visible Features
options are only available for feature layers.
Browse
—The extent will be based on an existing dataset.Intersection of Inputs
—The extent will be based on the minimum or intersecting extent of all inputs. If none of the inputs overlap, a null extent with all zeroes will result. This option is only available in the geoprocessing environment settings.Union of Inputs
—The extent will be based on the maximum or combined extent of all the inputs. This option is only available in the geoprocessing environment settings.Clipboard
—The extent can be copied to and from the clipboard.Copy Extent
—Copies the extent coordinates and coordinate system to the clipboard.Paste Extent
—Pastes the extent coordinates and, optionally, the coordinate system from the clipboard. If the clipboard values do not include a coordinate system, the extent will use the map’s coordinate system.
The extent coordinates are copied to and pasted from the clipboard using the same formatting and order as the ArcPy
Extentobject: x-min, y-min, x-max, y-max, and the spatial reference.Reset Extent
—The extent will be reset to the default value.
For coordinates that are manually provided, the values must be numeric and in the active map's coordinate system.
Caution:
The map may use different display units than the provided coordinates. The use of a cardinal direction (N, S, E, W) is not supported. Use a negative value sign for south and west coordinates.
An extent has a coordinate system, displayed in the Extent Coordinate System section, which is used by tools to interpret the location of the extent coordinates. The extent's coordinate system is determined as follows:
, Draw Extent
, and Extent of a Layer
—The extent uses the active map's coordinate system.Browse
and Clipboard
—The extent uses the dataset’s or pasted coordinate system.Intersection of Inputs
and Union of Inputs
—The tool determines the constraining extent and coordinate system at run time.
- This video was created with ArcGIS Pro 3.3.
Both custom map extents and layer clipping allow you to limit the data drawn on the map but have no impact on the data processed by geoprocessing tools.
