Use a geoprocessing tool
Once you find a geoprocessing tool and open it, specify its parameter values and run it.
To get help for an open tool in the Geoprocessing pane, hover over the Help button to access a summary and illustration of the tool, or click the button to open the tool reference page.
Parameters
After the tool opens, specify the tool's parameter values. Parameters are a set of options or settings, such as the input data to process, output dataset, and other options that modify how the tool runs. Every geoprocessing tool has a unique set of parameters. For information about each tool parameter, hover over the information button that appears next to the parameter's label.
Parameters can be required or optional and are treated as follows:
  • Required parameters must be filled in for the tool to run and are indicated by a red asterisk .
  • Optional parameters can be left blank or unmodified to use a default behavior.
Geoprocessing tools have both input and output parameters.
Input parameters
Input parameters can include datasets to be processed and options that control what a tool does. There are several ways to specify the input datasets processed by a tool, including the following:
  1. Select a map layer from a drop-down list.
    Selecting a layer typically honors the selection, highlight, or filter on a layer, which will process a subset of its features when you run a tool.
  2. Browse to a dataset that is in a project database, folder, or connection using the browse button .
  3. Create input features interactively using the interactive input button .
Tool input parameter
For input parameters that are not data, you typically only need to specify a number, check a box, or select an option from a list. Some parameters require more interaction, such as multiple values, geographic extent, expression, or field map.
Output parameters
Geoprocessing tools can create an output dataset or modify an input dataset.
An output parameter is the location of a new dataset or resulting value created by the tool. For output dataset parameters, the output location and name can be automatically assigned based on your current or scratch workspace. You can specify the path of the dataset using the Browse button or the Memory workspace button .
Modify the location that browse initially opens to using the Initial browse location option.
Geoprocessing tool outputs can overwrite an existing dataset when the Allow geoprocessing tools to overwrite existing datasets geoprocessing option is checked. Some geoprocessing tools support the following additional Overwrite Options settings at the bottom of the pane:
  • Delete existing and create new Delete existing and create new—The tool deletes the original dataset and creates a dataset in its place. This is the default.
  • Append to existing Append to existing—The tool maintains the existing dataset records and appends the tool output records to it. The dataset's schema will not change.
  • Replace existing records Replace existing records—The tool maintains the existing dataset but deletes all records in the existing dataset and replaces them with the tool output records. The dataset's schema will not change.
Caution:
When you use the Append to existing and Replace existing records options, the following conditions apply:
  • The geometry type must match the existing feature class, or the tool will return an error.
  • If the spatial reference of the new features do not match the existing dataset, the new features will be projected.
  • If the output fields produced by the tool do not match the existing dataset’s fields, the new fields will be excluded from the output.
Reset parameter settings
To reset a tool to its default parameter state, open the Run menu at the bottom of the Geoprocessing pane, and select Reset Parameters.
Override default parameter values
You can override the default parameter values of system geoprocessing tools using the Pro.settingsConfig file. Include the ToolParameters element in the file to set and, optionally, lock tool parameter values. Tools that have been configured with parameter overrides open with the specified value, rather than system-defined default values. For example, you can set the Calculate Field tool’s Expression Type parameter to use ArcGIS Arcade as the default rather than Python using the following syntax:
<Geoprocessing>
  <ToolParameters>
    <Parameter toolName="calculatefield" toolboxAlias="management" name="expression_type" isLocked="true">ARCADE</Parameter>
  </ToolParameters>
</Geoprocessing>
Parameter overrides only apply to tools opened in the Geoprocessing pane and in a floating window. The overrides are not used when a tool is run in Python or ModelBuilder unless the parameter value is specified.
Environments
You can modify additional options that affect tool performance on the tool Environments tab. All environment settings are optional. Only the geoprocessing environments that apply to the specific open tool will be displayed on the Environments tab.
Environment options set from the Environments tab will only be applied to that specific instance of running the tool. If you reopen the tool from geoprocessing history, the environment settings will be retained; otherwise, all environment settings will be the default values. To set geoprocessing environments that should be applied to all geoprocessing performed in the project, set environments from the Environments window by clicking Analysis > Geoprocessing > Environments.
Learn more about geoprocessing environment settings
The Environments tab may not display when a tool is opened in a floating window from a ribbon button or UI command. Set the project environments from the Environments window described above to apply environment settings when necessary.
Run a tool
To run a geoprocessing tool, click the Run button at the bottom of the Geoprocessing pane.
Status banner, progress, and messages
After you run a tool, a status banner is added to the bottom of the Geoprocessing pane with a progress bar that shows completion percentage and a cancel button to stop processing.
You can hover over the banner or progress bar to display a pop-up containing information about the tool that is running, such as messages, run time, and the specified tool parameters and environments. You can click View Details to access the same detailed information in a detached window, or click Open History to open the project's geoprocessing history.
The status banner also has a link to access the Suggestions list, which includes tools that may help you get to the next step in your geoprocessing workflow. Suggestions are based on the previous tools you ran in the current project, which are logged in the geoprocessing history.
Learn more about geoprocessing tool suggestions
When the tool is finished running, any output layers are added to the open map.
Use the Add output datasets to an open map and Show toggle to add output datasets to open map options to control whether tool outputs are added to the open map or scene.
When a tool runs from the Geoprocessing pane, a progress bar displays an icon and message to indicate the tool status as follows:
Icon
Status
Check mark
The tool completed successfully.
Warning
The tool completed with warnings. Click View Details or hover over the status icon to view the warning messages.
Error
The tool failed. Click View Details or hover over the status icon to view the error messages.
Use the Show notification when tool completes option to show a pop-up notification when a tool run is complete.
When you finish running a geoprocessing tool, click the Back button at the top of the Geoprocessing pane to return to the last page you viewed.
Suggestions
Geoprocessing tool suggestions are tools that may help you get to the next step in your geoprocessing workflow. Suggestions are based on the previous tools you ran in the current project, which are logged in the geoprocessing history. If you clear the geoprocessing history or you're working on a new project, no suggestions will be listed.
If the Tool Suggestions AI model is enabled during ArcGIS Pro installation, suggestions are available in the following locations:
  • After you run a tool, the Suggestions list is in the tool status banner.
  • The Favorites tab in the Geoprocessing pane has suggestions.
Suggestions use a prediction model that has been trained with tool usage sequences from the Esri User Experience Improvement program. The suggested tools have been used in sequences with the tools you previously ran by the ArcGIS Pro user community.
There is some randomization that occurs in the prediction, and you can retrieve alternative suggestions. If none of the suggestions apply to your workflow, click Try Again to get alternative suggestions.
If you do not enable tool suggestions when you install the software, you can enable it later by modifying the setup.
Suggestions require a processor that supports the AVX2 instruction set. If this hardware requirement is not met, even if the tool suggestions model file is installed, suggestions will not be available.
Schedule a tool
From the Run menu, select Schedule to run the tool at a later date and time and, optionally, with recurrence. All required parameters must be specified to schedule a tool.
Learn more about scheduling geoprocessing tools
Copy a Python command
To copy a Python command snippet that you can use to run the tool in Python with the currently specified parameters and environments, from the Run menu, select Copy Python Command. The Python code is copied to the clipboard, and you can paste it into the Python window, a notebook, or other Python interface.
It is not necessary to run the tool before copying the Python command. However, all required parameter values must be specified to enable the Copy Python Command option.
Python commands can also be copied from geoprocessing history entries.
Run modes and threads
When you open a tool in the Geoprocessing pane, you can use the Run Modes menu next to the Run button to change the thread the tool uses to run.
A geoprocessing tool can run on the following threads:
  • Geoprocessing thread—This thread is a background thread dedicated to running geoprocessing tools. While a tool runs on the geoprocessing thread, you can still interact with the application and map. Use this thread to run tools that are expected to take more than a minute to complete. This is the default option, unless there are pending edits or the Enable Undo toggle button is turned on.
  • Foreground thread—The main foreground thread is one of the four worker threads that govern the Cartographic Information Model (CIM). The foreground thread may provide faster processing times than the geoprocessing thread. Since you cannot interact with the application while a tool is running on the foreground thread, use this thread to run tools that are expected to take a few seconds to complete.
Learn more about run modes and threads
History and recent tools
When a geoprocessing tool is run, an entry is added to the project's geoprocessing history with details about when the tool was run, the settings that were used, whether the tool completed successfully, and any information, warning, or error messages.
The Favorites tab in the Geoprocessing pane also has a Recent section that lists the tools you have recently run.
Tools that have been recently run display a status indication icon and a list of recent instances of the tool. You can hover over the entries in the list to see details, and click to open the selected tool with the parameter settings that were previously used.
Recently run geoprocessing tools
Open and run multiple tools
In the Geoprocessing pane, you can open multiple geoprocessing tools, see a list of the open tools, and switch between them.
To open multiple tools, complete the following steps:
  1. Open a geoprocessing tool.
  2. Click the Add button in the upper right corner of the Geoprocessing pane to open a menu that lists all the open geoprocessing tools.
  3. Select Open Another Tool.
    The Geoprocessing pane returns to the previous page and adds the name of the first opened tool to the list of open tools. All changes to the previous tool are saved and will be loaded when the tool is reopened from this menu.
  4. Search for or select another tool and open it.
  5. Click the Add button in the Geoprocessing pane to see the list of multiple open tools.
You can switch between all open tools without losing any progress, as the parameter and environment settings are maintained as long as the tool remains in the open tool list.
You can run multiple tools, and they will be added to a queue of running tools that can be viewed in the geoprocessing history. If you run a tool while another tool is running, the second tool will be in a pending state until the first tool completes, at which time the next pending tool will run automatically.
