Connections to document databases in ArcGIS Pro
Create a database connection in the Catalog pane in ArcGIS Pro to authenticate access to Elasticsearch or OpenSearch.
To use data in one of these document databases, create a query layer in a map.
Creating a connection to a document database in ArcGIS Pro creates a database connection file (.dbconn).
For instructions to create a connection, see one of the following:
To publish a web feature layer or publish a map image layer that references the data, register the connection with a server that is federated with the active portal.
