ST_Geometry in PostgreSQL
The ST_Geometry spatial data type can be used in PostgreSQL databases that contain a geodatabase and those that do not. The ST_Geometry data type allows you to integrate spatial data with other types of business data, so the multiuser database gains the advantage of adding a geographic component to analyses and data products. Keeping spatial data together with other business objects also simplifies multiuser access, management, and data security, because you will then manage fewer data storage resources.
To use the ST_Geometry type in geodatabases in PostgreSQL, copy the st_geometry library to the PostgreSQL installation before you create a geodatabase. For instructions, see Create a geodatabase in PostgreSQL on Windows or Create a geodatabase in PostgreSQL on Linux. If you use a PostgreSQL database that does not contain a geodatabase, you can install the ST_Geometry type for use in spatial tables you create in the database.
Use the following links to learn about the ST_Geometry type in PostgreSQL:
Understand the architecture of the ST_Geometry spatial type in PostgreSQL.
Use ArcGIS to create feature classes that use ST_Geometry storage.
Use ArcGIS to access PostgreSQL tables that contain ST_Geometry columns.
Register an ST_Geometry column to restrict the spatial reference that can be used.
Access the ST_Geometry SQL function reference PDF.
How ST_Geometry stores spatial data
The following is the description of ST_Geometry in PostgreSQL:
Name |
Type |
Description |
size |
LONG INTEGER |
The total length of the ST_Geometry structure including shape buffer |
srid |
LONG INTEGER |
Contains the identifier for the geometry that links it to its associated spatial reference (coordinate system) record in the sde_spatial_references table |
numpts |
LONG INTEGER |
The number of points defining the geometry; for multipart geometries, this includes the separators between each part, one point for each separator |
entity |
SHORT INTEGER |
The type of geometric feature stored in the spatial column (linestring, multilinestring, multipoint, multipolygon, point, or polygon) |
sqltype |
SHORT INTEGER |
The SQL type for the shape; for example, POINT_TYPE, POINTM_TYPE, or MULTIPOLYGONZM_TYPE |
minx |
LFLOAT |
Together with miny, maxx, and maxy, defines the spatial envelope of the geometry |
miny |
LFLOAT |
Together with minx, maxx, and maxy, defines the spatial envelope of the geometry |
maxx |
LFLOAT |
Together with minx, miny, and maxy, defines the spatial envelope of the geometry |
maxy |
LFLOAT |
Together with minx, miny, and maxx, defines the spatial envelope of the geometry |
minz |
LFLOAT |
The minimum z-value |
maxz |
LFLOAT |
The maximum z-value |
minm |
LFLOAT |
The minimum measure value |
maxm |
LFLOAT |
The maximum measure value |
area |
LFLOAT |
The area of the geometry |
len |
LFLOAT |
The perimeter length of the geometry |
shape |
BYTEA |
The Esri compressed shape |
Like other object types, the ST_Geometry data type contains a constructor method and functions. A constructor method returns a new instance (object) of the data type and sets up the values of its attributes.
The name of the constructor is the same as the type (ST_Geometry). When you instantiate an object of the ST_Geometry type, you invoke the constructor method, as shown in the following example:
CREATE TABLE hazardous_sites (name varchar(128), location st_geometry);
The following are ST_Geometry accessor functions that take a single ST_Geometry as input and return the requested property value as a number:
The ST_Area member function returns the area of a geometry.
ST_Length returns the length of a geometry.
ST_Entity returns a number containing a bit mask that describes the entity type.
ST_NumPoints returns the number of points (vertices) that define a geometry.
ST_MinM, ST_MinX, ST_MinY, and ST_MinZ return the minimum desired coordinate of a geometry.
ST_MaxM, ST_MaxX, ST_MaxY, and ST_MaxZ return the maximum desired coordinate of a geometry.
ST_SRID returns the spatial reference identifier for a geometry.
For example, the following query returns the name and area of the individual states in the United States:
SELECT name, st_area(geometry)
FROM us_states
ORDER BY name;
ST_LineString, ST_MultiLineString, ST_MultiPoint, ST_MultiPolygon, ST_Point, and ST_Polygon are all subtypes (or subclasses) of ST_Geometry. ST_Geometry and its subtypes share common attributes and functions. The constructor definition for ST_LineString, ST_MultiLineString, ST_MultiPoint, ST_MultiPolygon, ST_Point, and ST_Polygon is the same. The name of the constructor is the same as that of the type it constructs.
ST_Geometry schema definition
The spatial type for PostgreSQL functions, tables, and views are stored in the sde schema. The schema definition is the base table description for system tables used to define and describe the type column/table, spatial index, and spatial reference information.
The tables are sde_geometry_columns and sde_coordinate_systems. The views are st_geometry_columns and st_spatial_references, and are based on these tables.
Dive in:
In addition to the system tables, views, and functions, the following database objects are used to maintain ST_Geometry information:
An sde login role
An sde schema in the database
An ST_Geometry trigger: sde_coord_sys_def_insert_tg
ST_Geometry domains:
st_geomcollection
st_linestring
st_multilinestring
st_multipoint
st_multipolygon
st_point
st_polygon
Use ArcGIS to create feature classes with ST_Geometry storage
You choose which storage type to use when you create feature classes using ArcGIS.
When you create a feature class in ArcGIS that uses ST_Geometry storage, the business table of the feature class is created with a column of type ST_Geometry in which spatial data for the feature class is stored.
In a database
By default, the ST_Geometry spatial type is used for the feature classes you create in a PostgreSQL database. To use a PostGIS spatial type, you must specify a different keyword when you create the feature class using an ArcGIS client. See Create a feature class for more information.
In a geodatabase
Feature class storage information is controlled by configuration keyword settings in a system table. You specify a configuration keyword when you create a feature class in ArcGIS. The DEFAULTS configuration keyword has the GEOMETRY_STORAGE parameter set to either ST_GEOMETRY (if you created the geodatabase to use ST_Geometry) or to PG_GEOMETRY (if you created the geodatabase to use PostGIS spatial types).
If the GEOMETRY_STORAGE parameter under the DEFAULTS keyword is set to use the PostGIS geometry or geography data type but users need to create some feature classes using the ST_Geometry data type, the geodatabase administrator must create a configuration keyword for ST_Geometry storage. Use the Export Geodatabase Configuration Keywords geoprocessing tool to export the contents of the system table to a text file, add a keyword that has the GEOMETRY_STORAGE parameter set to ST_GEOMETRY, and use the Import Geodatabase Configuration Keywords geoprocessing tool to import the changes. For example, you could export the system table contents to a text file and add a configuration keyword as follows:
##ST_GEOMETRY
GEOMETRY_STORAGE "ST_GEOMETRY"
UI_TEXT "User-interface for ST_GEOMETRY keyword"
END
For more information, see Alter configuration keywords.
Once the keyword has been added, anyone can specify it when they create a feature class in ArcGIS.
Use ArcGIS to access PostgreSQL tables with ST_Geometry columns
If you use SQL to create a table with an ST_Geometry column, you can access the data through SQL, custom third-party applications, and ArcGIS. When you connect to the database from ArcGIS, you can view, perform analyses, or load data into tables that contain an ST_Geometry column. To do this, the following criteria must be met:
The table must have a single ST_Geometry column.
The table must have no other columns of a user-defined type.
If the table stores multiple types of geometry (points, lines, and polygons), you must specify which geometry types you want to view; only one type at a time can be viewed in ArcGIS.
All records in the table must use the same spatial reference.
If you created the table in a geodatabase using SQL, you can register the table with the geodatabase if you want to use geodatabase functionality (such as replication, networks, relationship classes, and topology) or you want to edit the table in ArcGIS. To register it with the geodatabase, the following criteria must be met:
The table must be owned by the user registering it.
It must have a single ST_Geometry column.
It must have no other columns of a user-defined type.
It must have a single type of geometry (points, lines, or polygons).
You must also have an integer, unique, not-NULL column that can be used as an object ID.
Register the ST_Geometry column
If you use SQL to create a table that contains an ST_Geometry column, you can register the column to use a specific spatial reference and dimensionality. That way, when you insert records through SQL, you cannot accidentally insert records that use a different spatial reference. To do this, use the sde.st_register_spatial_column function. The syntax for using this function is as follows:
SELECT st_register_spatial_column('<database_name>', '<schema_name>', '<table_name>', '<spatial_column_name>', <srid>, <coordinate_dimension>)
The SRID you specify must exist in the public.sde_spatial_references table. The coordinate dimension indicates whether the data has only x,y coordinates (2), x,y,z coordinates (3), x,y,z,m coordinates (4), or x,y,m coordinates (5). By default, if you do not specify a coordinate dimension, the data is registered as having only x,y dimensions.
In the following example, the shape column of the blocks table in the sasha schema of database mycitydb is registered to use an SRID of 4236 and store only three-dimensional coordinates:
SELECT st_register_spatial_column('mycitydb', 'sasha', 'blocks', 'shape', 4236, 3);
This adds a record for the spatial column to the public.sde_geometry_columns table in the geodatabase or database.
If the spatial column is empty and you register it with a particular SRID and dimensionality, you could unregister it to change the SRID or dimensionality and then register it with different values. You can unregister a spatial column by running the st_unregister_spatial_column() function. This function removes the spatial column from the public.sde_geometry_columns system table so the spatial column is no longer associated with any spatial reference system. The syntax for using this function is as follows:
SELECT st_unregister_spatial_column('<database_name>', '<schema_name>',
'<table_name>', '<column_name>')
You can check to see whether a spatial column is registered by running the st_isregistered_spatial_column function. The syntax to use this function is as follows:
SELECT st_isregistered_spatial_column('<database_name>', '<schema_name>',
'<table_name>', '<column_name>', <srid>)
If the spatial column is registered with the specified SRID, 1 is returned; a 0 is returned if it is not.
To discover what dimensionality the table was registered with, use the st_get_coord_dimension function. The syntax for the st_get_coord_dimension function is as follows:
SELECT st_get_coord_dimension('<schema_name>', '<table_name>', '<column_name>', <srid>)
In this example, st_get_coord_dimension returns xyz since the blocks table is registered as three-dimensional:
SELECT st_get_coord_dimension('sasha', 'blocks', 'shape', 4236);
This returns the following:
xyz
