ArcGIS Reality mapping product generation
Available with Standard or Advanced license.
Reality Mapping user extension.
ArcGIS Reality for ArcGIS Pro allows you to generate various types of 2D and 3D products from drone, digital aerial, satellite, and scanned aerial photography. The product types that can be generated depend on the workspace type created, either Reality mapping or Ortho mapping.
Ortho mapping workspace
With an Ortho mapping workspace, you can generate the following 2D products using the product wizard once adjustment is completed:
  • Digital surface model (DSM)
  • Digital terrain model (DTM)
  • Orthomosaic
The Multiple Products wizard allows you to generate all or a subset of the products in a single process.
The Ortho mapping workspace does not support the generation of 3D products.
Reality mapping workspace
Using the Reality mapping workspace, you can generate the following 2D and 3D products using the product wizard once adjustment is completed:
  • True Ortho
  • DSM Mesh
  • Point Cloud
  • 3D Mesh
  • Gaussian Splats
The Multiple Products wizard enables you to generate all or any subset of the products in a single process.
Product generation best practices
Product generation using ArcGIS Reality for ArcGIS Pro is resource intensive. To optimize performance and reduce processing duration, the following best practices are recommended:
  • Use a dedicated local or cloud compute system—not a shared resource—that has a current CPU, above-average GPU, sufficient solid-state disk (SSD) storage, and at least 64 GB RAM to support product generation in a timely manner. For example, use a CPU with 3.0 GHz, or higher, clock speed per core, and a NVIDIA RTX GPU. For additional information on system requirements, see Introduction to the ArcGIS Reality for ArcGIS Pro extension.
    For generating Gaussian Splats, a computer with the following hardware specification is required:
    • Current CPU with minimum 64 GB RAM
    • NVIDIA GPU with minimum 8GB VRAM and a compute capability of 7.5 or higher.
    Check your computer’s compute capability at the NVIDIA site.
  • Following project creation, set up the processing environment in ArcGIS Pro by defining CPU and GPU parameters, including the following:
    • Set Parallel processing factor to 85%.
    • Set Processor Type to GPU, if available. CPU is the default.
      To access the environment settings, click the Analysis tab on the ArcGIS Pro ribbon, and click Environments in the Geoprocessing group.
  • When generating Gaussian Splats, using multi-look digital aerial imagery or drone imagery, where high overlap percentages (80/60) produce the best results. Satellite imagery is not supported for Gaussian Splat generation.
  • When digital aerial imagery is composed of both nadir and oblique data, consider the following before processing:
    • Use only the nadir imagery when creating DSM, DTM, True Ortho, and DSM Mesh products. Including oblique imagery will adversely impact processing time.
    • Use both nadir and oblique imagery when generating Point Cloud and 3D Mesh products.
      A True Ortho can also be generated from data composed of both oblique and nadir imagery. However, the processing duration significantly increases when compared to using only nadir imagery.
  • If you're creating a DSM mesh from satellite imagery, color balancing is required before product generation.
  • When you create a DSM using satellite imagery, the default vertical coordinate system (VCS) of the output DSM is WGS84 (ellipsoidal height). If you need to convert the output to a different projection or coordinate system, use the Project tool.
  • It is recommended that you use the panchromatic band—not a pansharpened image—for generating a DSM and DTM. This is to ensure that data with the highest pixel quality is used to support image correlation and the elevation generation process.
  • Constrain product generation to the area of interest only by defining a product boundary in the Advanced Product Settings pane.
  • Prioritize product processing. If both 2D and 3D products are required, create 2D products first since 3D products require more processing time.
